MAX233 troubles
Hi everyone! I am working on a Basic Stamp 2 OEM project using the
Maxim MAX233 IC. I need to use the MAX233 to make the Basic Stamp's
connection to the computer more reliable. I built the MAX233 portion
according to the Maxim supplied datasheet, and with the help of a
Basic Stamp book. Unfortunately, the circuit only produces a garbled
output when fed through the Maxim IC. I am using the built-in DB9
port on the Basic Stamp 2 OEM. When the output of the Basic Stamp is
fed directly through the DB9 port to the computer, the serial output
is clear and appears correctly in the Basic Stamp terminal. I have
checked the circuit connections many times, and the baud settings in
the editor are correct. Do you have any suggestions on what might be
wrong? Thanks.
Jacob
wrong? Thanks.
Jacob
In other words, -12V = logic 1 and +12V = Logic 0.
http://www.lennard.net.nz/
Ben Lennard, NCEE, Dip EE
Electronics R&D
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
> From: "jacobhpower" <jacobhpower@m...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Sun, 06 Oct 2002 02:10:27 -0000
> Subject: [noparse][[/noparse]basicstamps] MAX233 troubles
> wrong? Thanks.
> Jacob
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
> of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
working again.
Jacob
Original Message
Wrom: MHV
Sent: Saturday, October 05, 2002 9:14 PM
Subject: Re: [noparse][[/noparse]basicstamps] MAX233 troubles
RS232 is negative logic. :-)
Electronics R&D
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
> Wrom: IBGDADRZFSQHYUCDDJBLVLMHAALPTCXLYRW
> wrong? Thanks.
> Jacob
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ Get
more from the Web. FREE MSN Explorer download : http://explorer.msn.com
