MAX233 troubles — Parallax Forums
MAX233 troubles
edited 2002-10-06 15:20 in General Discussion
Hi everyone! I am working on a Basic Stamp 2 OEM project using the
Maxim MAX233 IC. I need to use the MAX233 to make the Basic Stamp's
connection to the computer more reliable. I built the MAX233 portion
according to the Maxim supplied datasheet, and with the help of a
Basic Stamp book. Unfortunately, the circuit only produces a garbled
output when fed through the Maxim IC. I am using the built-in DB9
port on the Basic Stamp 2 OEM. When the output of the Basic Stamp is
fed directly through the DB9 port to the computer, the serial output
is clear and appears correctly in the Basic Stamp terminal. I have
checked the circuit connections many times, and the baud settings in
the editor are correct. Do you have any suggestions on what might be
wrong? Thanks.
Jacob
    edited 2002-10-06 04:59
    RS232 is negative logic. :-)
    In other words, -12V = logic 1 and +12V = Logic 0.
    http://www.lennard.net.nz/
    Ben Lennard, NCEE, Dip EE
    Electronics R&D
    Hm: +64 4 972 7567
    Mb: +64 21 536 627
    87 Spencer Street
    Crofton Downs
    Wellington
    New Zealand
    "To the optimist, the glass is half full. To the pessimist, the glass is
    half empty. To the engineer, the glass is twice as big as it needs to be."
    No animals were harmed in the transmission of this email, although the
    Dog next door is living on borrowed time, let me tell you! Those of you
    with an overwhelming fear of the unknown will be gratified to learn that
    there is no hidden message revealed by reading this warning backwards.
    > From: "jacobhpower" <jacobhpower@m...>
    > Reply-To: basicstamps@yahoogroups.com
    > Date: Sun, 06 Oct 2002 02:10:27 -0000
    > Subject: [noparse][[/noparse]basicstamps] MAX233 troubles
    > wrong? Thanks.
    > Jacob
    > of the message will be ignored.
    Thanks for the response! I changed my programming and now my project is
    working again.
    Jacob
    Wrom: MHV
    Sent: Saturday, October 05, 2002 9:14 PM
    Subject: Re: [noparse][[/noparse]basicstamps] MAX233 troubles
    Electronics R&D
    Hm: +64 4 972 7567
    Mb: +64 21 536 627
    87 Spencer Street
    Crofton Downs
    Wellington
    New Zealand
    > Wrom: IBGDADRZFSQHYUCDDJBLVLMHAALPTCXLYRW
    > wrong? Thanks.
    > Jacob
    Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ Get
    more from the Web. FREE MSN Explorer download : http://explorer.msn.com
