Alternative for LM358
Hello.
I use the LM358 to drive LED`s but the output could be higher.
Know anybody a alternative for the LM358 with more output?
Thanks for help, Kai
>Hello.
What do you want the LEDs to do? If they are just ON or OFF, a ULN2003 or
ULN2803 gives you 7 or 8 channels in one package.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
8 buffered lines. I use this chip to monitor the 8 bit data bus on my Stamp
Projects, and it lights up those LEDs very well.
Take a look at my I2C page and the I2C to 8 bit parallel converter to see
how I use it...
http://www.lennard.net.nz/ click on circuit ideas then I2C.
cheers,
Ben, Wellington, New Zealand.
> From: "Kai Kuehle" <kai@u...>
> Organization: University of Paderborn
> Reply-To: basicstamps@yahoogroups.com
> Date: Thu, 3 Oct 2002 21:23:18 +0200
> To: <basicstamps@yahoogroups.com>
> Subject: [noparse][[/noparse]basicstamps] Alternative for LM358
> Hello.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
> of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
one 330 ohm resistor per LED... Otherwise the LEDs change brightness a
bit...
> From: Ben <ben@l...>
> Date: Fri, 04 Oct 2002 08:40:20 +1200
> Subject: Re: [noparse][[/noparse]basicstamps] Alternative for LM358
> How about a 74HC245?
> how I use it...
> cheers,
>> Hello.
>> Body
