Alternative for LM358 — Parallax Forums
edited 2002-10-03 21:43 in General Discussion
Hello.
I use the LM358 to drive LED`s but the output could be higher.
Know anybody a alternative for the LM358 with more output?
Thanks for help, Kai
    edited 2002-10-03 20:38
    At 09:23 PM 10/3/02 +0200, Kai Kuehle wrote:
    >Hello.
    What do you want the LEDs to do? If they are just ON or OFF, a ULN2003 or
    ULN2803 gives you 7 or 8 channels in one package.
    dwayne
    Dwayne Reid <dwayner@p...>
    Trinity Electronics Systems Ltd Edmonton, AB, CANADA
    (780) 489-3199 voice (780) 487-6397 fax
    Celebrating 18 years of Engineering Innovation (1984 - 2002)
    Do NOT send unsolicited commercial email to this email address.
    This message neither grants consent to receive unsolicited
    commercial email nor is intended to solicit commercial email.
    edited 2002-10-03 21:40
    How about a 74HC245?
    8 buffered lines. I use this chip to monitor the 8 bit data bus on my Stamp
    Projects, and it lights up those LEDs very well.
    Take a look at my I2C page and the I2C to 8 bit parallel converter to see
    how I use it...
    http://www.lennard.net.nz/ click on circuit ideas then I2C.
    cheers,
    Ben, Wellington, New Zealand.
    > From: "Kai Kuehle" <kai@u...>
    > Organization: University of Paderborn
    > Reply-To: basicstamps@yahoogroups.com
    > Date: Thu, 3 Oct 2002 21:23:18 +0200
    > To: <basicstamps@yahoogroups.com>
    > Subject: [noparse][[/noparse]basicstamps] Alternative for LM358
    > Hello.
    > of the message will be ignored.
    Ideally, for your use Kai, the one 470 ohm resistor should be replaced with
    one 330 ohm resistor per LED... Otherwise the LEDs change brightness a
    bit...
    > From: Ben <ben@l...>
    > Date: Fri, 04 Oct 2002 08:40:20 +1200
    > Subject: Re: [noparse][[/noparse]basicstamps] Alternative for LM358
    > how I use it...
    > cheers,
    >> Hello.
    >> Body
