serial out command
I would like to connect a modem to my BS2 to send simple commands like
dial the phone at 2400 baud, I would like to connect the RX line on the
modem through a inverter like a 7404 to provide buffering. Question is,
what number do I give it to set up the baud rate at 2400 inverted, if
that's what I need?
thanks so much for your kind response,
Leroy Hall
that's what I need?
Leroy Hall
I would try again..
that's what I need?
Leroy Hall
LTNS
Assuming it is a straight BS2, baudmode values are:
for 2400 Direct which is inverted, 8 bit no parity use 16780.
for 7 bits w/ even parity use 24927.
Different Stamps have different baudmode values, I believe they are all in
the manual.
Chris
Original Message
> From: Leroy Hall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=krezWfL55zNv9dutJDaHS9CBE8hx_FfjEjTN1ITr6Nf0mEWDq7U03FWTQoPmxXN87Ds8sf8]leroy@f...[/url
> Sent: Tuesday, October 01, 2002 5:32 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] serial out command
> I didn't get any response on my first try on this message, so
> I thought
> I would try again..
> line on the
> Question is,
> that's what I need?
> Leroy Hall
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Thanks for the info Chris, I will try this and see if I can get it to
work. My wife's mother doesn't speak English and sometimes she needs to
contact my wife. I wanted to just have a button on the wall that she
pushes, makes a light light and then my wife's cell phone is rang.
Sounds like a good job for the stamp, so I thought I would try it.
thanks again,
Leroy
"Chris Loiacono (E-mail)" wrote:
> Hi LeRoy:
> LTNS
> the manual.
> Chris
Original Message
> > From: Leroy Hall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uiaxaNWCAu5r-4SlMrhQRjjouXY58WoN6M4NNf0DC_n6kx9_DJDLMjlZ62yTUIcl9B-e5jo]leroy@f...[/url
> > I thought
> > I would try again..
> > line on the
> > Question is,
> > that's what I need?
> > Leroy Hall
> from the same email address that you subscribed. Text in the Subject and Body
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
