translation
Hello, I'm trying to use a keyboard encoder (Hagstrom KE24) to enable a pic
or stamp to send key presses to a pc application. I'm having trouble
getting it to work using serial data, I.E. Micron sends serial data to the
rs232 port on the keyboard encoder, keyboard encoder sends key data to pc.
I've verified that the serial data is being sent correctly (using
hyperterminal), and I've set the baud rate on the KE24 to match the baud
rate of the micron.
Has anyone done this? Any advice?
rate of the micron.
modulation frequency as 4KHz. How would this translate into a data rate?
I want to use it to send data between the stamp and a computer. Would the
data rate be 4000bps or something less than this?
Matt
[noparse][[/noparse]This E-mail scanned for viruses by Declude Virus]
be the maximum data rate.
Original Message
From: weeksmp@m... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pl_u7Tj9_MgMJUWTpuPvVbf5CkNWNTjj_V8gf67OTl4tP3YomWUNo_wYNsyC8W6k-CrBIlFVe_0AIgiiqDGCFQ]weeksmp@m...[/url
Sent: Monday, September 16, 2002 3:31 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] translation
I am looking at the specs. of a small transmitter which lists the max
Matt
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
This e-mail message may contain legally privileged and/or confidential
information. If you are not the intended recipient(s), or the employee
or agent responsible for delivery of this message to the intended
recipient(s), you are hereby notified that any dissemination,
distribution or copying of this e-mail message is strictly prohibited.
If you have received this message in error, please immediately notify
the sender and delete this e-mail message from your computer.
