translation — Parallax Forums
translation
edited 2002-09-16 20:34 in General Discussion
Hello, I'm trying to use a keyboard encoder (Hagstrom KE24) to enable a pic
or stamp to send key presses to a pc application. I'm having trouble
getting it to work using serial data, I.E. Micron sends serial data to the
rs232 port on the keyboard encoder, keyboard encoder sends key data to pc.
I've verified that the serial data is being sent correctly (using
hyperterminal), and I've set the baud rate on the KE24 to match the baud
rate of the micron.
Has anyone done this? Any advice?
    edited 2002-09-16 20:31
    I am looking at the specs. of a small transmitter which lists the max
    modulation frequency as 4KHz. How would this translate into a data rate?
    I want to use it to send data between the stamp and a computer. Would the
    data rate be 4000bps or something less than this?
    Matt
    [noparse][[/noparse]This E-mail scanned for viruses by Declude Virus]
    Without some fancy encoding, such as phase shift keying, 4,000 bps will also
    be the maximum data rate.
    From: weeksmp@m... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pl_u7Tj9_MgMJUWTpuPvVbf5CkNWNTjj_V8gf67OTl4tP3YomWUNo_wYNsyC8W6k-CrBIlFVe_0AIgiiqDGCFQ]weeksmp@m...[/url
    Sent: Monday, September 16, 2002 3:31 PM
    Subject: [noparse][[/noparse]basicstamps] translation
    Matt
    This e-mail message may contain legally privileged and/or confidential
    information. If you are not the intended recipient(s), or the employee
    or agent responsible for delivery of this message to the intended
    recipient(s), you are hereby notified that any dissemination,
    distribution or copying of this e-mail message is strictly prohibited.
    If you have received this message in error, please immediately notify
    the sender and delete this e-mail message from your computer.
