Clock Signal...
Hello All,
Can a clock signal drive more than one digital(TTL) I.C.? If so,
how many I.C.'s can I drive, before I have to worry about "loading" the
clock signal down? This is a BS2 project, but I admit that the question is
slightly off-topic.
Tim
P.S. Martin, the Stamps In Class Industrial Control text was just what I
needed. Thank you for pointing me in that direction.
Timothy Medema
CrystaLite, Incorporated
3307 Cedar St. (425) 745-6000 800-666-6065
Everett, WA 98201 Fax: (425) 257-0232
www.crystaliteinc.com
<mailto:timm@c...>timm@c...
The information transmitted is intended only for the person or entity to
whom it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you received
this in error, please contact the sender and delete the material from any
computer.
slightly off-topic.
Tim
Timothy Medema
computer.
>Hello All,
>slightly off-topic.
This depends on a few factors such as speed, what your output driver is
capable of, and the overall distance from the clock source.
>Thanks,
>Tim
>Timothy Medema
Beau Schwabe Mask Designer II - ATL
National Semiconductor Enterprise Networking Business Unit
500 Pinnacle Court, Suite 525 Wired Communications Division
Mail Stop GA1 Norcross, GA 30071
a 7404 or similar. If you need to "fan out" to a LOT of chips you can
parallel the inputs to the 7404 (6 in a package) then you can drive many,
many loads like that.
Mike B.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Friday, September 13, 2002 8:25 AM
Subject: [noparse][[/noparse]basicstamps] Clock Signal...
> Hello All,
is
> slightly off-topic.
> Thanks,
> Tim
> Timothy Medema
> computer.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
To answer your questions Beau, the clock signals are slow in this
application - less than 100Hz, the clock is capable of supplying at least
50mA, and the longest distance needed from the source is only 4 inches or
so. I'd like to use this signal as clock input to three or four other
basic digital I.C.'s. Mike, I so appreciate that you included part numbers
for a "fan-out" configuration. I'll add this to my education archives.
Tim
Timothy Medema
computer.
