multiple 74hc595 devices
Any code examples of how to communicate to multiple 74hc595 devices?
I want to turn on 48 LEDs one at a time in sequence until all 48 LEDs
are on, then turn them off, then start all over. I'll use 6 595s but
right now I have three linked. All RCK and SRCK lines are tied
together and the first serout is connected to the second device serin
(pin 9-to-14) and the second to the third.
Guy
Guy
in the number of bits you want to get to. In other words if you want to
read the second 8 bits from the second 595 shift in 16 bits (with the \16
modifier). I am not sure what the limit is on number of bits to shift but
if it is smaller than 48 then you will need to do it in a loop and store the
first bits until you get all the ones you need. Sounds like a pain but
remember the chip is guaranteed to shift releabily up to 30 Mhz so you won't
be wasting much time..
Ok, I just looked, you can shift in up to 16 bits at a time, so simply
shift in 16, store them and repeat that 2 more times to get all 48 bits.
Depending on which chip you are using it will shift in at about 42 Khz which
is pretty fast.
Mike B.
P.S. Every where I said "shift in", replace it with shift out ! I'll
always get the LS165 and LS595 mixed up but the functions are identical in
operation.
. mb
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, September 04, 2002 9:57 AM
Subject: [noparse][[/noparse]basicstamps] multiple 74hc595 devices
> Thanks,
> Guy
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
together; data goes from the Stamp and daisy-chains through. Simple. If you
have this setup:
[noparse][[/noparse]Stamp]-->[noparse][[/noparse]A]-->[noparse][[/noparse]B]-->[noparse][[/noparse]C]-->[noparse][[/noparse]D]-->[noparse][[/noparse]E]-->[noparse][[/noparse]F]
... you need to make sure that you shift the data for unit F out first. The
data for unit E will push it along, and so-forth until the data for unit A
has been shifted out. At that point, you would pulse the latch pin(s) to
move the new data to the outputs.
So, your output commands will look like this:
SHIFTOUT dPin, cPin, MSBFirst, [noparse][[/noparse]unitF, unitE, unitD, unitC, unitB, unitA]
PULSOUT Latch, 5
Hope this helps.
-- Jon Williams
-- Parallax
In a message dated 9/4/02 5:08:48 PM Central Daylight Time, w6ffc@p...
writes:
> Guy I'll check to make sure, but I think it is simply a matter of shifting
> is pretty fast.
> Mike B.
> operation.
> . mb
Original Message
> From: "digital_interior" <guyb@m...>
> > Thanks,
> > Guy
and the serial data from the stamp to "A" out of "A" to "B" out
of "B" to "C". I can shift out 16 bits of data MSBfirst to the device
chain and get correct results on the devices "A" and "B". What is
happening is device "C" seems to be getting that same data as "A".
Device "C" outputs are a copy of "A".
Then I tried shifting out 8 bits of data to the device chain and
again the same, device "C" was displaying output status identical
to "A" and Device "B" was idle (no output change).
What are your thoughts?
Guy
--- In basicstamps@y..., jonwms@a... wrote:
> It's not tough to use multiple '595s. Connect the clock and latch
lines
Simple. If you
> have this setup:
first. The
unit A
(s) to
unitB, unitA]
> PULSOUT Latch, 5
> Hope this helps.
> -- Jon Williams
> -- Parallax
w6ffc@p...
> writes:
shifting
want to
the \16
shift but
and store the
pain but
so you won't
simply
48 bits.
42 Khz which
> > is pretty fast.
> > Mike B.
out ! I'll
identical in
> > operation.
> > . mb
Original Message
> > To: <basicstamps@y...>
devices?
48 LEDs
595s but
serin
> > > Thanks,
> > > Guy
It depends on how you are writing your code. For
example, if you have three 595's strung together, the
end of your SHIFTOUT command could have
[noparse][[/noparse]128\8,0\16]which would turn on (or off) the last
output of the last 595 in the chain.
Hope this helps
Chuck
--- digital_interior <guyb@m...> wrote:
> I do have the units connected with clock and latch
> going to all three
> to "B" out
> "B". What is
> same data as "A".
> device chain and
> status identical
> Guy
> clock and latch
> lines
> Simple. If you
> > have this setup:
> for unit F out
> first. The
> until the data for
> unit A
> pulse the latch pin
> (s) to
> unitD, unitC,
> unitB, unitA]
> > PULSOUT Latch, 5
> > Hope this helps.
> > -- Jon Williams
> > -- Parallax
> Daylight Time,
> w6ffc@p...
> > writes:
> simply a matter of
> shifting
> other words if you
> want to
> in 16 bits (with
> the \16
> number of bits to
> shift but
> do it in a loop
> and store the
> Sounds like a
> pain but
> so you won't
> bits at a time, so
> simply
> times to get all
> 48 bits.
> shift in at about
> 42 Khz which
> > > is pretty fast.
> > > Mike B.
> it with shift
> out ! I'll
> functions are
> identical in
> > > operation.
> > > . mb
Original Message
> multiple 74hc595
> devices?
> sequence until all
> 48 LEDs
> over. I'll use 6
> 595s but
> SRCK lines are tied
> the second device
> serin
> > > > Thanks,
> > > > Guy
> removed]
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
Yahoo! Finance - Get real-time stock quotes
http://finance.yahoo.com
bits to fill your devices. If you have three devices, you should shift 24
bits (three bytes, one per 595) and then latch the outputs.
I would suggest using byte variables for your 595 data -- it will be easier
for you to do testing with by using specific values (output patterns) and
testing your output subroutine.
-- Jon Williams
In a message dated 9/4/02 8:19:20 PM Central Daylight Time, guyb@m...
writes:
> I do have the units connected with clock and latch going to all three
Thanks for all the help. See if this makes any sense to you guys:
I took all the suggestions, reviewed and tweaked my code last night.
In my case what I did was indeed to break up my data into "word" size
variables (16-bit blocks of data for each pair of 595s in the chain,
a pair represents the 16-bits). So, with my 4 595 devices I only
needed to deal with two 16-bit, "word" size variables. Then
sent/shifted these variables out in the reverse order (last pair of
devices first). I suppose if I broke out my data into "byte" size
variables (8-bit blocks of data for each individual 595 in the chain)
I would then send/shift out these 8-bit variables in the reverse
order of each device in the chain, needing four 8-bit "byte" size
variables.
Now I'm off to get more 595 devices for my prototyping.
Thanks again.
Guy
> I think you're latching the outputs before you should and not
shifting enough
shift 24
be easier
patterns) and
> -- Jon Williams
guyb@m...
> writes:
three
device
as "A".
guyb@m... writes:
For Guy
Did you know you can do what you want with 2 595's ?
48 LEDs can be handled by a 6 x 8 matrix.
For example, connect 8 LEDs to Qh on the first chip. Connect the ground lead
of one LED to Qh on the second chip, the next LED to Qg, the next to Qf, and
so on. Then write
start
low latch
pulsout dout, clk, lsbfirst, [noparse][[/noparse]%11111110] 'turns on first LED
pulsout dout, clk, lsbfirst, [noparse][[/noparse]%00000001]
pulsout latch, 10
low latch
pause 500
low latch
shiftout dout, clk, lsbfirst, [noparse][[/noparse]%111111100] 'turns on 2nd LED
shiftout dout, clk, lsbfirst, [noparse][[/noparse]%00000001]
pulsout latch, 10
low latch
pause 500
and so on for the next 6 LEDs
goto start
I'm sure you can figure out the programming for the 8 LEDs connected to Qg,
Qf, and so on. When you get thru there will be 8 LEDs on Qa thru Qh, and one
the second chip 8 LEDs to Qh thruQc.
Also, did you know you can use decimal numbers instead of binary ?
Shiftout dout, clk, lsbfirst, [noparse][[/noparse]253]
is the same as
shiftout dout, clk, lsbfirst, [noparse][[/noparse]%11111101]
and a lot less typing.
Sid Weaver - W4EKQ
Christmas is coming
Remember - Fumpus tegit .
