multiple 74hc595 devices — Parallax Forums
edited 2002-09-05 15:21 in General Discussion
Any code examples of how to communicate to multiple 74hc595 devices?
I want to turn on 48 LEDs one at a time in sequence until all 48 LEDs
are on, then turn them off, then start all over. I'll use 6 595s but
right now I have three linked. All RCK and SRCK lines are tied
together and the first serout is connected to the second device serin
(pin 9-to-14) and the second to the third.
Guy
    edited 2002-09-04 22:37
    Guy I'll check to make sure, but I think it is simply a matter of shifting
    in the number of bits you want to get to. In other words if you want to
    read the second 8 bits from the second 595 shift in 16 bits (with the \16
    modifier). I am not sure what the limit is on number of bits to shift but
    if it is smaller than 48 then you will need to do it in a loop and store the
    first bits until you get all the ones you need. Sounds like a pain but
    remember the chip is guaranteed to shift releabily up to 30 Mhz so you won't
    be wasting much time..
    Ok, I just looked, you can shift in up to 16 bits at a time, so simply
    shift in 16, store them and repeat that 2 more times to get all 48 bits.
    Depending on which chip you are using it will shift in at about 42 Khz which
    is pretty fast.
    Mike B.
    P.S. Every where I said "shift in", replace it with shift out ! I'll
    always get the LS165 and LS595 mixed up but the functions are identical in
    operation.
    . mb
    Sent: Wednesday, September 04, 2002 9:57 AM
    Subject: [noparse][[/noparse]basicstamps] multiple 74hc595 devices
    > Thanks,
    > Guy
    edited 2002-09-04 23:22
    It's not tough to use multiple '595s. Connect the clock and latch lines
    together; data goes from the Stamp and daisy-chains through. Simple. If you
    have this setup:
    [noparse][[/noparse]Stamp]-->[noparse][[/noparse]A]-->[noparse][[/noparse]B]-->[noparse][[/noparse]C]-->[noparse][[/noparse]D]-->[noparse][[/noparse]E]-->[noparse][[/noparse]F]
    ... you need to make sure that you shift the data for unit F out first. The
    data for unit E will push it along, and so-forth until the data for unit A
    has been shifted out. At that point, you would pulse the latch pin(s) to
    move the new data to the outputs.
    So, your output commands will look like this:
    SHIFTOUT dPin, cPin, MSBFirst, [noparse][[/noparse]unitF, unitE, unitD, unitC, unitB, unitA]
    PULSOUT Latch, 5
    Hope this helps.
    -- Jon Williams
    -- Parallax
    In a message dated 9/4/02 5:08:48 PM Central Daylight Time, w6ffc@p...
    writes:
    > is pretty fast.
    > Mike B.
    > operation.
    > . mb
    > From: "digital_interior" <guyb@m...>
    > > Thanks,
    > > Guy
    edited 2002-09-05 01:58
    I do have the units connected with clock and latch going to all three
    and the serial data from the stamp to "A" out of "A" to "B" out
    of "B" to "C". I can shift out 16 bits of data MSBfirst to the device
    chain and get correct results on the devices "A" and "B". What is
    happening is device "C" seems to be getting that same data as "A".
    Device "C" outputs are a copy of "A".
    Then I tried shifting out 8 bits of data to the device chain and
    again the same, device "C" was displaying output status identical
    to "A" and Device "B" was idle (no output change).
    What are your thoughts?
    Guy
    lines
    Simple. If you
    > have this setup:
    first. The
    unit A
    (s) to
    unitB, unitA]
    > PULSOUT Latch, 5
    > Hope this helps.
    > -- Jon Williams
    > -- Parallax
    w6ffc@p...
    > writes:
    shifting
    want to
    the \16
    shift but
    and store the
    pain but
    so you won't
    simply
    48 bits.
    42 Khz which
    > > is pretty fast.
    > > Mike B.
    out ! I'll
    identical in
    > > operation.
    > > . mb
    > > To: <basicstamps@y...>
    devices?
    48 LEDs
    595s but
    serin
    > > > Thanks,
    > > > Guy
    edited 2002-09-05 02:16
    Greetings,
    It depends on how you are writing your code. For
    example, if you have three 595's strung together, the
    end of your SHIFTOUT command could have
    [noparse][[/noparse]128\8,0\16]which would turn on (or off) the last
    output of the last 595 in the chain.
    Hope this helps
    Chuck
    > going to all three
    > to "B" out
    > "B". What is
    > same data as "A".
    > device chain and
    > status identical
    > Guy
    > clock and latch
    > lines
    > Simple. If you
    > > have this setup:
    > for unit F out
    > first. The
    > until the data for
    > unit A
    > pulse the latch pin
    > (s) to
    > unitD, unitC,
    > unitB, unitA]
    > > PULSOUT Latch, 5
    > > Hope this helps.
    > > -- Jon Williams
    > > -- Parallax
    > Daylight Time,
    > w6ffc@p...
    > > writes:
    > simply a matter of
    > shifting
    > other words if you
    > want to
    > in 16 bits (with
    > the \16
    > number of bits to
    > shift but
    > do it in a loop
    > and store the
    > Sounds like a
    > pain but
    > so you won't
    > bits at a time, so
    > simply
    > times to get all
    > 48 bits.
    > shift in at about
    > 42 Khz which
    > > > is pretty fast.
    > > > Mike B.
    > it with shift
    > out ! I'll
    > functions are
    > identical in
    > > > operation.
    > > > . mb
    > multiple 74hc595
    > devices?
    > sequence until all
    > 48 LEDs
    > over. I'll use 6
    > 595s but
    > SRCK lines are tied
    > the second device
    > serin
    > > > > Thanks,
    > > > > Guy
    > removed]
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do You Yahoo!?
    Yahoo! Finance - Get real-time stock quotes
    http://finance.yahoo.com
    edited 2002-09-05 05:55
    I think you're latching the outputs before you should and not shifting enough
    bits to fill your devices. If you have three devices, you should shift 24
    bits (three bytes, one per 595) and then latch the outputs.
    I would suggest using byte variables for your 595 data -- it will be easier
    for you to do testing with by using specific values (output patterns) and
    testing your output subroutine.
    -- Jon Williams
    In a message dated 9/4/02 8:19:20 PM Central Daylight Time, guyb@m...
    writes:
    edited 2002-09-05 14:32
    I got it!
    Thanks for all the help. See if this makes any sense to you guys:
    I took all the suggestions, reviewed and tweaked my code last night.
    In my case what I did was indeed to break up my data into "word" size
    variables (16-bit blocks of data for each pair of 595s in the chain,
    a pair represents the 16-bits). So, with my 4 595 devices I only
    needed to deal with two 16-bit, "word" size variables. Then
    sent/shifted these variables out in the reverse order (last pair of
    devices first). I suppose if I broke out my data into "byte" size
    variables (8-bit blocks of data for each individual 595 in the chain)
    I would then send/shift out these 8-bit variables in the reverse
    order of each device in the chain, needing four 8-bit "byte" size
    variables.
    Now I'm off to get more 595 devices for my prototyping.
    Thanks again.
    Guy
    shifting enough
    shift 24
    be easier
    patterns) and
    > -- Jon Williams
    guyb@m...
    > writes:
    three
    device
    as "A".
    In a message dated 09/05/2002 09:33:14 Eastern Daylight Time,
    guyb@m... writes:
    For Guy
    Did you know you can do what you want with 2 595's ?
    48 LEDs can be handled by a 6 x 8 matrix.
    For example, connect 8 LEDs to Qh on the first chip. Connect the ground lead
    of one LED to Qh on the second chip, the next LED to Qg, the next to Qf, and
    so on. Then write
    start
    low latch
    pulsout dout, clk, lsbfirst, [noparse][[/noparse]%11111110] 'turns on first LED
    pulsout dout, clk, lsbfirst, [noparse][[/noparse]%00000001]
    pulsout latch, 10
    low latch
    pause 500
    low latch
    shiftout dout, clk, lsbfirst, [noparse][[/noparse]%111111100] 'turns on 2nd LED
    shiftout dout, clk, lsbfirst, [noparse][[/noparse]%00000001]
    pulsout latch, 10
    low latch
    pause 500
    and so on for the next 6 LEDs
    goto start
    I'm sure you can figure out the programming for the 8 LEDs connected to Qg,
    Qf, and so on. When you get thru there will be 8 LEDs on Qa thru Qh, and one
    the second chip 8 LEDs to Qh thruQc.
    Also, did you know you can use decimal numbers instead of binary ?
    Shiftout dout, clk, lsbfirst, [noparse][[/noparse]253]
    is the same as
    shiftout dout, clk, lsbfirst, [noparse][[/noparse]%11111101]
    and a lot less typing.
    Sid Weaver - W4EKQ
    Christmas is coming
    Remember - Fumpus tegit .
