Power Supply Design
I am building a circuit that will be controlled by a Stamp II, but
powered by an LM2940 5 Volt Regulator (just like the one on the BOE).
Regarding the LM2940, it looks like I need to have a capacitor
between Vin and ground and another capacitor between Vout and
ground. Every book I look at, every article I read, every circuit I
see, has a different set of values for the capacitors. Even the BOE
uses a 1.0 uf tantalum cap between Vout and ground when the spec
sheet seems to indicate that... "The minimum output capacitance
required to maintain stability is 22 µF (this value may be increased
without limit). Larger values of output capacitance will give
improved transient response."
The Vin source will be a 9v transistor battery.
What values should I be using for the two capacitors? Do I need to
worry about using an aluminum electrolytic cap (for Vin and ground)
and a tantalum cap (for Vout and ground) given a relatively low
voltage source?
Thanks for hopefully clearing up a mystery!
voltage source?
regulators will sometimes go wacko and fail to regulate if you leave off the
caps. The regulator gets hot and you burn up whatever it is you are
powering.
Keep in mind most of the examples in the data sheets and so-forth are for
circuits powered off a DC power supply and not a battery. This could account
for the difference in capacitor values.
Original Message
voltage source?
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> Whatever you do, don't run it without the caps. For some reason
those
leave off the
> powering.
are for
could account
Original Message
BOE).
> voltage source?
> basicstamps-unsubscribe@y...
Subject and
Otherwise use the values off the data sheet.
Keep in mind you can't run much off a 9-volt battery anyway, so why not use
the Stamp regulator? Anything else that does not require a regulated source
can be run directly off the battery.
Original Message
Thanks for the insight! Any idea as to what values I should be using?
those
leave off the
> powering.
are for
could account
Original Message
BOE).
> voltage source?
