Power Supply Design — Parallax Forums
Power Supply Design
edited 2002-09-03 20:26 in General Discussion
I am building a circuit that will be controlled by a Stamp II, but
powered by an LM2940 5 Volt Regulator (just like the one on the BOE).
Regarding the LM2940, it looks like I need to have a capacitor
between Vin and ground and another capacitor between Vout and
ground. Every book I look at, every article I read, every circuit I
see, has a different set of values for the capacitors. Even the BOE
uses a 1.0 uf tantalum cap between Vout and ground when the spec
sheet seems to indicate that... "The minimum output capacitance
required to maintain stability is 22 µF (this value may be increased
without limit). Larger values of output capacitance will give
improved transient response."
The Vin source will be a 9v transistor battery.
What values should I be using for the two capacitors? Do I need to
worry about using an aluminum electrolytic cap (for Vin and ground)
and a tantalum cap (for Vout and ground) given a relatively low
voltage source?
Thanks for hopefully clearing up a mystery!
    edited 2002-09-03 19:58
    Whatever you do, don't run it without the caps. For some reason those
    regulators will sometimes go wacko and fail to regulate if you leave off the
    caps. The regulator gets hot and you burn up whatever it is you are
    powering.
    Keep in mind most of the examples in the data sheets and so-forth are for
    circuits powered off a DC power supply and not a battery. This could account
    for the difference in capacitor values.
    voltage source?
    edited 2002-09-03 20:06
    Thanks for the insight! Any idea as to what values I should be using?
    those
    leave off the
    > powering.
    are for
    could account
    BOE).
    > voltage source?
    > basicstamps-unsubscribe@y...
    Subject and
    If you plan to run off batteries, the Parallax values should be fine.
    Otherwise use the values off the data sheet.
    Keep in mind you can't run much off a 9-volt battery anyway, so why not use
    the Stamp regulator? Anything else that does not require a regulated source
    can be run directly off the battery.
    those
    leave off the
    > powering.
    are for
    could account
    BOE).
    > voltage source?
