Shiftin
I am trying to shiftin 52 synchronous bits from a mitutoyo digital
depth mic. The depth mic provides a clock and 52 bits. The Basic
stamp only needs to pull a request line low to start the
transmission. I am having trouble recieving this information with
shiftin because it allows for an internal clock only.
Is there any way around this? I have tried to write a loop to
recieve the data, but the BS2p40 doesn't execute code fast enough to
keep up with the external clock that is running at ~3.0Kbs.
thanks
mike Dolan
NJ
thanks
mike Dolan
NJ
The SHIFTIN command is made for synchronous devices, which give their own
clock.
I think 3 Kbps is not too fast for the Stamp. Check the mode value to be
sure that the bits to be transmited are at a stable state when the sampling
occurs.
Does the Mitutoyo send all 52 bits in one shot ?
Phil.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, August 14, 2002 5:52 PM
Subject: [noparse][[/noparse]basicstamps] SHIFTIN
> thanks
> mike Dolan
> NJ
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
If shiftin is made for devices which give there own clock. Then
maybe the manual is confusing me? Why does it read?
Cpin is a variable/constant/expression(0-15) that specifies the I/O
pin that will be connected to the synchronous serial device's clock
input. This pin will be set in output mode.
If it were setup to recieve a clock signal I would imagine it would
be set up in input not output mode.
Yes, the mitutoyo device simultaniously sends out 52 clk and data
pulses, and the microprocessor is supposed to read the data on the
rising or falling edge of the clock pulses.
When I couldn't set ShiftIN to recieve clock pulses I decided to
write a loop. Where in1 is the data, and IN2 is the clk from the
depth mic.
'for counter = 0 to 51
'Again:
'IF IN2 = 1 then Again
'rawdata(counter) = IN1
'NEXT
This is not working and I think it's because the processor can't keep
up. At 10,000 lines/sec these 4 lines will take approximately .0004
seconds, and the 52 bits are coming out in 16ms as measured on my
scope and confirmed on the mitutoyo datasheet. The loop needs to
execute 52 times to recieve the data, 52x.0004sec is a 20ms, this is
is a longer period then the 16ms that it takes for all of the pulses
to come out.
I know the signal is stable because I am watching it on an Analog
scope.
what do you think
mike
--- In basicstamps@y..., "Philippe Derenne" <derennep@b...> wrote:
> Hi Mike,
their own
> clock.
to be
sampling
> occurs.
> Phil.
Original Message
> From: "lightningshack" <MikDolan54@a...>
> To: <basicstamps@y...>
Basic
with
to
> > thanks
> > mike Dolan
> > NJ
> > basicstamps-unsubscribe@y...
Subject and
Oops, I was a little bit too fast...
Whit SHIFTIN, the Stamp is giving the clock to the serial device, so Cpin is
an output (synchronous data transfert).
So, if the serial device is the 'clock master', it is *asynchronous* data
transfert (on Stamp's point of view), and you must use SERIN.
Then, you must know and/or set the baudrate of the Mitutoyo. Let's say 9600
baud. You have to use the right baudmode for this speed, and the Stamp must
be 'listening' when data goes out of the Mitutoyo. You may put the SERIN
command into a waiting loop.
Would this be more helpfull ?
Phil.
Original Message
Sent: Wednesday, August 14, 2002 8:00 PM
Subject: [noparse][[/noparse]basicstamps] Re: SHIFTIN
> Phil,
> depth mic.
> 'Again:
> 'NEXT
> to come out.
> scope.
> what do you think
> mike
setup to be a master; not a slave.
-- Jon Williams
-- Parallax
In a message dated 8/14/02 12:26:47 PM Central Daylight Time,
derennep@b... writes:
thanks for the help, that CD4031 might just do the trick..
mike
Can anybody translate this porgram to use a command other then
SHIFTIN. I am looking to avoid using SHIFTIN and maybe use PULSIN,
is that possible?
I am eading MAX187 ADC values
Yossi
'{$STAMP BS2}
sclk CON 5
cs CON 6
serdata CON 7
adc VAR Word
main:
GOSUB convert
GOSUB print
PAUSE 500
GOTO main
print:
DEBUG DEC adc,CR
RETURN
convert:
LOW cs
SHIFTIN serdata,sclk,MSBPOST,[noparse][[/noparse]adc\12]
HIGH cs
RETURN
