Shiftin — Parallax Forums
Shiftin
edited 2003-10-28 13:47 in General Discussion
I am trying to shiftin 52 synchronous bits from a mitutoyo digital
depth mic. The depth mic provides a clock and 52 bits. The Basic
stamp only needs to pull a request line low to start the
transmission. I am having trouble recieving this information with
shiftin because it allows for an internal clock only.
Is there any way around this? I have tried to write a loop to
recieve the data, but the BS2p40 doesn't execute code fast enough to
keep up with the external clock that is running at ~3.0Kbs.
thanks
mike Dolan
NJ
    edited 2002-08-14 18:25
    Hi Mike,
    The SHIFTIN command is made for synchronous devices, which give their own
    clock.
    I think 3 Kbps is not too fast for the Stamp. Check the mode value to be
    sure that the bits to be transmited are at a stable state when the sampling
    occurs.
    Does the Mitutoyo send all 52 bits in one shot ?
    Phil.
    Sent: Wednesday, August 14, 2002 5:52 PM
    Subject: [noparse][[/noparse]basicstamps] SHIFTIN
    > thanks
    > mike Dolan
    > NJ
    edited 2002-08-14 19:00
    Phil,
    If shiftin is made for devices which give there own clock. Then
    maybe the manual is confusing me? Why does it read?
    Cpin is a variable/constant/expression(0-15) that specifies the I/O
    pin that will be connected to the synchronous serial device's clock
    input. This pin will be set in output mode.
    If it were setup to recieve a clock signal I would imagine it would
    be set up in input not output mode.
    Yes, the mitutoyo device simultaniously sends out 52 clk and data
    pulses, and the microprocessor is supposed to read the data on the
    rising or falling edge of the clock pulses.
    When I couldn't set ShiftIN to recieve clock pulses I decided to
    write a loop. Where in1 is the data, and IN2 is the clk from the
    depth mic.
    'for counter = 0 to 51
    'Again:
    'IF IN2 = 1 then Again
    'rawdata(counter) = IN1
    'NEXT
    This is not working and I think it's because the processor can't keep
    up. At 10,000 lines/sec these 4 lines will take approximately .0004
    seconds, and the 52 bits are coming out in 16ms as measured on my
    scope and confirmed on the mitutoyo datasheet. The loop needs to
    execute 52 times to recieve the data, 52x.0004sec is a 20ms, this is
    is a longer period then the 16ms that it takes for all of the pulses
    to come out.
    I know the signal is stable because I am watching it on an Analog
    scope.
    what do you think
    mike
    --- In basicstamps@y..., "Philippe Derenne" <derennep@b...> wrote:
    > Hi Mike,
    their own
    > clock.
    to be
    sampling
    > occurs.
    > Phil.
    > From: "lightningshack" <MikDolan54@a...>
    > To: <basicstamps@y...>
    Basic
    with
    to
    > > thanks
    > > mike Dolan
    > > NJ
    > > basicstamps-unsubscribe@y...
    Subject and
    edited 2002-08-14 19:21
    Mike,
    Oops, I was a little bit too fast...
    Whit SHIFTIN, the Stamp is giving the clock to the serial device, so Cpin is
    an output (synchronous data transfert).
    So, if the serial device is the 'clock master', it is *asynchronous* data
    transfert (on Stamp's point of view), and you must use SERIN.
    Then, you must know and/or set the baudrate of the Mitutoyo. Let's say 9600
    baud. You have to use the right baudmode for this speed, and the Stamp must
    be 'listening' when data goes out of the Mitutoyo. You may put the SERIN
    command into a waiting loop.
    Would this be more helpfull ?
    Phil.
    Sent: Wednesday, August 14, 2002 8:00 PM
    Subject: [noparse][[/noparse]basicstamps] Re: SHIFTIN
    > Phil,
    > depth mic.
    > 'Again:
    > 'NEXT
    > to come out.
    > scope.
    > what do you think
    > mike
    edited 2002-08-14 19:32
    The BASIC Stamp provides the clock for both SHIFTIN and SHIFTOUT. It is
    setup to be a master; not a slave.
    -- Jon Williams
    -- Parallax
    In a message dated 8/14/02 12:26:47 PM Central Daylight Time,
    derennep@b... writes:
    edited 2002-08-15 13:46
    Tracy,
    thanks for the help, that CD4031 might just do the trick..
    mike
    Hello All,
    Can anybody translate this porgram to use a command other then
    SHIFTIN. I am looking to avoid using SHIFTIN and maybe use PULSIN,
    is that possible?
    I am eading MAX187 ADC values
    Yossi
    '{$STAMP BS2}
    sclk CON 5
    cs CON 6
    serdata CON 7
    adc VAR Word
    main:
    GOSUB convert
    GOSUB print
    PAUSE 500
    GOTO main
    print:
    DEBUG DEC adc,CR
    RETURN
    convert:
    LOW cs
    SHIFTIN serdata,sclk,MSBPOST,[noparse][[/noparse]adc\12]
    HIGH cs
    RETURN
