ATN Line Noise...
Hello Everyone,
I am using two BS2's in the preliminary testing for the wireless
application that I had asked for your help with earlier. I now have them
"talking" to one another, but once in a while, one or the other BS2
hangs-up or just freezes mid-program -- most of the time not in the same
place in either program. I suspect noise on the ATN line of the Serial
Port, so I'm using the 0.1 capacitors as shown in the Version 2.0 Stamp
Manual, but the problem persists. I thought that Tracy Allen had also
recommended a resistor in the mix also (ATN pull-down?) on his page
http://www.emesys.com/BS2bugs.htm#top , but the link listed as "Unwanted
resets form noise on the Serial Port ATN line" does not seem to go
anywhere. Anyone have any other ideas? Can I put a pull-down resistor on
the ATN line? Does anything need to be done with any of the other Serial
Port lines?
Tim
Timothy Medema
CrystaLite, Incorporated
3307 Cedar St. (425) 745-6000 800-666-6065
Everett, WA 98201 Fax: (425) 257-0232
www.crystaliteinc.com
<mailto:timm@c...>timm@c...
The information transmitted is intended only for the person or entity to
whom it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you received
this in error, please contact the sender and delete the material from any
computer.
Port lines?
Tim
Timothy Medema
computer.
separate breadboards, one for each wireless "end".
Tim
At 07:41 AM 8/8/2002 -0700, you wrote:
>Hello Everyone,
>Port lines?
>Thanks,
>Tim
>Timothy Medema
>computer.
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
timm@c... writes:
> Port lines?
For Tim:
Make sure that when one xmtr is sending that the associated recvr is
completely disabled. Are you using transceivers or separate xmtrs and
rcvrs ?
Sid
http://www.faq-pro.com/faq/index.php?qframe=1&faq=1&article=22
Part of the Stamp FAQ at http://www.wd5gnr.com/stampfaq.htm
Al Williams
AWC
* NEW: PAK-VIa - Read PS/2 keyboards or mice -- double the buffer, lower
current consumption.
http://www.al-williams.com/awce/pak6.htm
Original Message
> From: Timothy Medema [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TCxUZNxwKQtf2L3ojlezTbfbsVIu0uxoYYaIPWu-fB9GkmzkmQdF_uIMuxUBRTAPnfzp96ETkb43Cocp]timm@c...[/url
> Sent: Thursday, August 08, 2002 9:42 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] ATN Line Noise...
> Hello Everyone,
> the wireless
> now have them
> in the same
> the Serial
> Version 2.0 Stamp
> had also
> as "Unwanted
> other Serial
> Port lines?
> Thanks,
> Tim
> Timothy Medema
> or entity to
> use of, or
> you received
> material from any
> computer.
> Subject and Body of the message will be ignored.
I am using the Parallax SIP transceivers with the fixed antennas,
Part No: 27997. Do I need to do something to ensure that the receivers are
disabled when transmitting? Pull the receive data line low? What I'm
testing right now is a MASTER/SLAVE configuration with the SLAVE running a
"listening" routine, the MASTER sends an a "get the slave's attention"
signal, the SLAVE responds with an "I'm ready for data" signal, the MASTER
transmits the "important data" and then the SLAVE responds with an
"acknowledge" signal.
Tim
At 10:57 AM 8/8/2002 -0400, you wrote:
>In a message dated 08/08/2002 10:43:01 Eastern Daylight Time,
>timm@c... writes:
> > Port lines?
>For Tim:
>rcvrs ?
>Sid
Thank you for your web information. Per that information though,
the programming cable should never be left connected. I have been using
DEBUG a lot to monitor one end or the other to view what's going on - are
you saying that this should not be done?
Tim
At 09:58 AM 8/8/2002 -0500, you wrote:
>Have a look at the FAQ:
>Al Williams
>AWC
Original Message
> > From: Timothy Medema [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7skrB3vAtBOdADISUMtT2EH50iYQy30mbMT8uQZMMtetzhGOKIsWaEyfogPq52PHsyHNW-MvIODwuO1q8IY]timm@c...[/url
> > Hello Everyone,
> > the wireless
> > now have them
> > in the same
> > the Serial
> > Version 2.0 Stamp
> > had also
> > as "Unwanted
> > other Serial
> > Port lines?
> > Thanks,
> > Tim
> > Timothy Medema
> > or entity to
> > use of, or
> > you received
> > material from any
> > computer.
Timothy Medema
computer.
Actually I didn't write that (if you notice, the author's name is at the
bottom). But I think what he means is don't leave the cable attached to
the BS2 and unattached at the other end.
Perhaps I'll edit that article to reflect that.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
Original Message
> From: Timothy Medema [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EMX-d3EKm0h9oX-fR3WzKAUEoWCOIsmXiV850KH4M5STD6xZcIDQax9-0-C437ovYtoJz-D8BG1ES6zhdA]timm@c...[/url
> Sent: Thursday, August 08, 2002 10:31 AM
> Subject: RE: [noparse][[/noparse]basicstamps] ATN Line Noise...
> Hello Al,
> information though,
> been using
> going on - are
> Tim
> >Al Williams
> >AWC
> >lower current consumption. http://www.al-williams.com/awce/pak6.htm
Original Message
> > > Hello Everyone,
> > > wireless application that I had asked for your help with
> earlier. I
> > > now have them
> other BS2
> > > the same place in either program. I suspect noise on the ATN line
> > > of the Serial
> > > Version 2.0 Stamp
> > > had also
> on his page
> > > "Unwanted resets form noise on the Serial Port ATN line" does not
> > > seem to go anywhere. Anyone have any other ideas? Can I put a
> > > other Serial
> > > Port lines?
> > > Thanks,
> > > Tim
> > > Timothy Medema
> > > entity to whom it is addressed and may contain
> confidential and/or
> > > privileged material. Any review, retransmission,
> dissemination or
> > > other use of, or
> by persons or
> > > received this in error, please contact the sender and delete the
> > > material from any
> > > computer.
> the Subject
> >and
> Timothy Medema
received
any
computer.
other end" so I am certain that what it means.
Al Williams
AWC
Original Message
> From: Timothy Medema [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aneAFv_8Nq4nocX8b8Z8bEhiVCMVWdlpBy12Rc6akVMnuEmoLLbw11ybK0z5fjNF_5DWhbP54QGtIKvWIQ]timm@c...[/url
> Hello Al,
> information though,
> been using
> going on - are
> Tim
> >Al Williams
> >AWC
Original Message
> > > Hello Everyone,
> earlier. I
> > > now have them
> other BS2
> > > of the Serial
> > > Version 2.0 Stamp
> > > had also
> on his page
> > > other Serial
> > > Port lines?
> > > Thanks,
> > > Tim
> > > Timothy Medema
> confidential and/or
> dissemination or
> > > other use of, or
> by persons or
> > > material from any
> > > computer.
> the Subject
> >and
> Timothy Medema
received
any
computer.
My mistake - haste makes waste, I should have read it closer
before posting. I have not left the programming cable "without the PC at
the other end" to act as a noise antenna, and have had the freezing problem
with both breadboards - with and without the cable connected for DEBUG
purposes.
Tim
At 10:39 AM 8/8/2002 -0500, you wrote:
>Oh, in fact, if you look at the question it says "without the PC at the
>Al Williams
>AWC
Original Message
> > From: Timothy Medema [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ifvY6zgGaV3rmmWZ3jRj4kaCy8JvhsGCbDUZ93xTO2lTuwNuvK9senK1lLiDGMlfN7EyD2MjkELJvwJo]timm@c...[/url
> > Hello Al,
> > information though,
> > been using
> > going on - are
> > Tim
> > >Al Williams
> > >AWC
Original Message
> > > > Hello Everyone,
> > earlier. I
> > > > now have them
> > other BS2
> > > > of the Serial
> > > > Version 2.0 Stamp
> > > > had also
> > on his page
> > > > other Serial
> > > > Port lines?
> > > > Thanks,
> > > > Tim
> > > > Timothy Medema
> > confidential and/or
> > dissemination or
> > > > other use of, or
> > by persons or
> > > > material from any
> > > > computer.
> > the Subject
> > >and
> > Timothy Medema
>received
>any
>computer.
Timothy Medema
computer.
timm@c... writes:
For Tim
I use separate units so I don't know the pins on the transceiver. Maybe the
recvr is automatically disabled when you transmit - don't know. I do know
that it is imperative that the associated recvr be disabled when transmitting.
I'm going to the Parallax site and have a look. I'll get back to you if I
find anything. I assume one of the breadboards is tied to your PC via the
serial cable so you can tell it what to xmit. Is the other breadboard a
stand-alone ?
Does it serout a message in response to a serin ?
Can't imagine the ATN line causing a problem.
Sid
pol. cap attached + to ATN and - to GND .1uf cap
I should have provided more information. Each "end" is a
stand-alone breadboard with a BS2 and transceiver. The transceiver is a
simple hook-up: +5VDC, Three Ground Pins, Tx Pin, and Rx Pin. The
transceiver is controlled by each BS2 using SEROUT to the Tx Pin to
transmit and SERIN form the Rx Pin to receive. The documentation supplied
with the transceiver modules is a single sheet by RF Digital, covering only
the VERY basics of hook-up and the mention of using SEROUT and SERIN
commands to transmit and receive - no code examples. Parallax tech support
has told me over the phone that they are writing additional
documentation. So, I guess I've taken the long way around to answer you
question - yes, I'm using the serial out and in commands. Wether or not
the one or the other side of the transceiver needs to be disabled while the
other side is being used, I don't know or have documentation on.
Does that help?
Tim
At 11:47 AM 8/8/2002 -0400, you wrote:
>In a message dated 08/08/2002 11:15:54 Eastern Daylight Time,
>timm@c... writes:
> are
>For Tim
>stand-alone ?
>Sid
Timothy Medema
computer.
>Port lines?
>Thanks,
>Tim
>Timothy Medema
>computer.
Thanks for the heads up on the link. It is fixed now to point here...
http://www.emesystems.com/BS2rs232.htm#resets
The circuit I use is this,
DB9S ---||
pin4 0.22 | 3.3k |
optional |
| 0.1 |
atn ground
which includes the resistor to lower the input resistance of the ATN
circuit from 10k down to 3k. The idea is to generate a short pulse
of that reaches 2.5 volts for a fraction of a millisecond into the
atn pin when a genuine 0-->5 volt stiff reset signal comes in on pin4
of the DB9. The response to the less stiff fake signals that come
from noise should not bring the circuit up to that reset threshold.
If you do a RC circuit model of capacitively coupled noise, it helps
to have the resistor in parallel with the ATN input, as well as the
capacitors.
-- Tracy
> >Hello Everyone,
> >Port lines?
> >Thanks,
> >Tim
> >Timothy Medema
> DB9S ---||
> pin4 0.22 | 3.3k |
> optional |
> | 0.1 |
> atn ground
>capacitors.
> -- Tracy
Hello Tracy,
I thought that I'd read (a long time ago) that you'd used a
resistor to lower the input impedance of the programming serial
port. Thank you for this information and for the link repair.
Much appreciated,
Tim
timm@c... writes:
> Does that help?
Very much. Let me check and I'll get back to you.
Sid
Tim
At 12:59 PM 8/8/2002 -0400, you wrote:
>In a message dated 08/08/2002 12:10:43 Eastern Daylight Time,
>timm@c... writes:
> > Does that help?
>Sid
timm@c... writes:
Tim, go to www.rfdigital.com. They are the manufacturers and should have
everything on their site. If you need to talk to them their number is
818-541-7622
Hope this helps.
Sid
Thanks for the link, but I've already been to RF Digital and they
don't have any additional information. The sheet that came with the
transceiver modules was written by RF Digital and has PRELIMINARY
DOCUMENTATION printed at the beginning and end of the information. It
would be a good idea to call them though.
Thanks for caring enough to put in that time to dig for me,
Tim
>timm@c... writes:
> the
>818-541-7622
>Hope this helps.
>Sid
