Correct zener diode and resistor
I wish to implement a zener diode and led between the 9v power supply and
stamp to indicate when their is insufficient power to operate the stamp
properly. 3 questions:
1. at what voltage does the stamp stop operating as it should?
2. Would the following circuit light an led when the voltage falls
below the minimum required?
stamp - 9v + ---zener ---resistor --> stamp
3. which zener ?
4. resistor size?(is a resistor needed?)
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp.
3. which zener ?
4.5 v, 4.0 v?)?
>From: "JOHN BELL" <johnabell8@h...>
>Reply-To: basicstamps@yahoogroups.com
>Subject: [noparse][[/noparse]basicstamps] CORRECT ZENER DIODE AND RESISTOR
>Date: Sun, 09 Jun 2002 20:51:25 -0400
>3. which zener ?
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
>Does anyone know at what voltage the Stamp stops operating properly(4.9 v,
>4.5 v, 4.0 v?)?
The reset circuit will trip if voltage drops to 4 volts - per the BS2 manual.
you could not really say it operates "properly" at that voltage,
because even a little bit of noise on the power supply can kick it
over the edge. I looked into it in some detail. If you want more
information, look here:
http://www.emesystems.com/BS2power.htm#Brownout
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
>4.5 v, 4.0 v?)?
> >3. which zener ?
