Correct zener diode and resistor — Parallax Forums
edited 2002-06-11 07:00 in General Discussion
I wish to implement a zener diode and led between the 9v power supply and
stamp to indicate when their is insufficient power to operate the stamp
properly. 3 questions:
1. at what voltage does the stamp stop operating as it should?
2. Would the following circuit light an led when the voltage falls
below the minimum required?
stamp - 9v + ---zener ---resistor --> stamp
3. which zener ?
4. resistor size?(is a resistor needed?)
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp.
    edited 2002-06-11 02:04
    Does anyone know at what voltage the Stamp stops operating properly(4.9 v,
    4.5 v, 4.0 v?)?
    >From: "JOHN BELL" <johnabell8@h...>
    >Reply-To: basicstamps@yahoogroups.com
    >Subject: [noparse][[/noparse]basicstamps] CORRECT ZENER DIODE AND RESISTOR
    >Date: Sun, 09 Jun 2002 20:51:25 -0400
    >3. which zener ?
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    MSN Photos is the easiest way to share and print your photos:
    http://photos.msn.com/support/worldwide.aspx
    edited 2002-06-11 02:45
    >4.5 v, 4.0 v?)?
    The reset circuit will trip if voltage drops to 4 volts - per the BS2 manual.
    The Stamp reset circuit kicks in at close to 4.3 volts. Of course,
    you could not really say it operates "properly" at that voltage,
    because even a little bit of noise on the power supply can kick it
    over the edge. I looked into it in some detail. If you want more
    information, look here:
    http://www.emesystems.com/BS2power.htm#Brownout
    -- regards,
    Tracy Allen
    mailto:tracy@e...
    >4.5 v, 4.0 v?)?
    > >3. which zener ?
