Anyone ! Please!
I am trying to assemble an infrared detection system for future use
on a bot,my problem is,all the scematics I've found use a 38khz IR
detector(3 pin)for more selectivity, and I happen to have a pile of
IR phototransistors
with matching IR LEDS (QEC113,QCE112,Fairchild). I'm sure there is
some way of using these, can someone point me in the right direction
as far as wiring and code.Thanks
IR phototransistors
receivers, they need to be pulsed. About 40 kHz seems to be the right
frequency. The IR receivers may also need some amplification and
filtering to receive the signal across the link. Just the detectors &
LED's are not sufficient by them selves for transmission much beyond 6"
or so -- if that much. A 555 timer chip and some amplification with a
small transistor 2n3904 might just work for you.
HTH,
Leroy
> IR phototransistors
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Thanks, I appreciate the help.I'm kinda new to this field, I've been
into the BEAM side of robotics until now,solar powered no micro's
ect.so photodiodes and touch sensors were the main mode of steering
and obstical avoidance.Whole new ball game here! Any idea of where I
can get some schematics on this topic for a BS2. I know I can just
buy a 40khz detector with matching LED but they seem a little tough
to locate and like I mentioned before I have a surplus of the other
components. Thanks again
In basicstamps@y..., Leroy Hall <leroy@f...> wrote:
> In order for those IR LED's to emit enough power to be seen by
your IR
right
detectors &
beyond 6"
with a
> HTH,
> Leroy
use
IR
of
> > IR phototransistors
is
direction
> > basicstamps-unsubscribe@y...
Subject and Body of the message will be ignored.
a 555 running at 38Khz driving a transistor switch that then drives the IR
LED.
