Anyone ! Please! — Parallax Forums
Anyone ! Please!
edited 2002-06-11 02:24 in General Discussion
I am trying to assemble an infrared detection system for future use
on a bot,my problem is,all the scematics I've found use a 38khz IR
detector(3 pin)for more selectivity, and I happen to have a pile of
IR phototransistors
with matching IR LEDS (QEC113,QCE112,Fairchild). I'm sure there is
some way of using these, can someone point me in the right direction
as far as wiring and code.Thanks
    edited 2002-06-10 16:27
    In order for those IR LED's to emit enough power to be seen by your IR
    receivers, they need to be pulsed. About 40 kHz seems to be the right
    frequency. The IR receivers may also need some amplification and
    filtering to receive the signal across the link. Just the detectors &
    LED's are not sufficient by them selves for transmission much beyond 6"
    or so -- if that much. A 555 timer chip and some amplification with a
    small transistor 2n3904 might just work for you.
    HTH,
    Leroy
    > IR phototransistors
    edited 2002-06-11 02:17
    Thanks, I appreciate the help.I'm kinda new to this field, I've been
    into the BEAM side of robotics until now,solar powered no micro's
    ect.so photodiodes and touch sensors were the main mode of steering
    and obstical avoidance.Whole new ball game here! Any idea of where I
    can get some schematics on this topic for a BS2. I know I can just
    buy a 40khz detector with matching LED but they seem a little tough
    to locate and like I mentioned before I have a surplus of the other
    components. Thanks again
    your IR
    right
    detectors &
    beyond 6"
    with a
    > HTH,
    > Leroy
    use
    IR
    of
    > > IR phototransistors
    is
    direction
    > > basicstamps-unsubscribe@y...
    Subject and Body of the message will be ignored.
    Any Radioshack store has the receiver for about $3.50. The emmitter is simply
    a 555 running at 38Khz driving a transistor switch that then drives the IR
    LED.
