How Do I Build A Switching System?
i would like to build a switching system that will turn on and off 16
car radios, 16 amplifiers, 16 front spekers, 16 rear speakers and 16
sub woofers. i am building a car audio display and would also like to
build my own switching system.
i would also like to control all of the switching from a IR receiver
and transmiter using a sony universal remote.
i need to know what products will be needed as well as a wiring
diagram of how to assemble the stamps and the programing instructions.
this is a real important project to me andi would greatley appriciate
some good help.
i currentley have in my possesion the board of education stamp kit.
i can provide more information if someone has more questions.
thanks in advance
todd.
some good help.
thanks in advance
todd.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, June 05, 2002 12:55 AM
Subject: [noparse][[/noparse]basicstamps] How Do I Build A Switching System?
> some good help.
> thanks in advance
> todd.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Don
Original Message
Sent: Wednesday, June 05, 2002 4:14 PM
Subject: Re: [noparse][[/noparse]basicstamps] How Do I Build A Switching System?
> And how much are you willing to pay for this TON of work?
Original Message
> From: "toddscaraudio2002" <toddscaraudio@m...>
> > some good help.
> > thanks in advance
> > todd.
and
options I can think of are 3 - 16 position dual contact rotary
switches. This in itself would probably work. Or you could use 3
groups of 16 sets of DPDT relays controlled by the stamp which would
look neater and probably be more expensive. I say DPDT because you would
probably have to switch the common connection, even though it is
common. If you know car audio systems, you probably know what I mean.
Also every K-mart & Walmart has one along with Circuit City. Maybe you
could ask a question there as well. I think it would be fun to design
such a thing. Hope this is a start anyway..
Leroy
16
16
to
receiver
instructions.
appriciate
> some good help.
> thanks in advance
> todd.
Are you looking to switch any radio with an speaker and any amp ?
Once you do the schematic, you may find that simple relays may be the
cheapest and simplest way to do your switching.
but 4 sets of 16 units (64 total units) will require quite an
elaborate set-up.
if you are just switching things on and off for a showroom style
display, can all the speakers share a common ground with just the
positive lead being switched ?
It seems that the Stamp would be needed only to accept the IR and
then signal the relays.
Dave
--- In basicstamps@y..., "toddscaraudio2002" <toddscaraudio@m...>
16
16
to
receiver
instructions.
appriciate
> some good help.
> thanks in advance
> todd.
Original Message
Sent: Wednesday, June 05, 2002 6:17 PM
To: basicstamps@yahoogroups.com
Original Message
> some good help.
> thanks in advance
> todd.
from the same email address that you subscribed. Text in the Subject and Body
The problem you are trying to solve isn't very hard the main problem is funds. I
take it from your email name and your question you are trying to set up some
sort of a display. What types of power levels are you talking about as far as
your amplifiers are concerned? Since these are car radios and I am assuming car
amplifiers you can utilize the 'remote' (blue wire) to turn them on and off. By
doing this you could set up a multiplexer system using either b.c.d. or SPI. and
32 relays could be eliminated right away. As far as the speakers are concerned
you would need to have some sort of a switching matrix... I am assuming you are
trying to set up a 'best buy' display system. Am I correct?
-Randy Knutson
Do You Yahoo!?
Sign-up for Video Highlights of 2002 FIFA World Cup
Original Message
Sent: Thursday, June 06, 2002 1:58 AM
Todd:
-Randy Knutson
Do You Yahoo!?
Original Message
Todd:
-Randy Knutson
Do You Yahoo!?
Original Message
Todd:
-Randy Knutson
Do You Yahoo!?
connection and can easily be controlled by a Stamp. They are typically
used in video systems and you "might" be able to pick up a freebie. I have
no idea about the power/frequency specs, but it might be something to check
on.
As for the bushel of relays option, there are many related messages in the
archives.
Good luck.
Original Message
> some good help.
> thanks in advance
> todd.
The information transmitted is intended only for the person
or entity to which it is addressed and may contain confidential
and/or privileged material. If you are not the intended recipient
of this message you are hereby notified that any use, review,
retransmission, dissemination, distribution, reproduction or any
action taken in reliance upon this message is prohibited. If you
received this in error, please contact the sender and delete the
material from any computer. Any views expressed in this message
are those of the individual sender and may not necessarily reflect
the views of the company.
Original Message
Sent: Thursday, June 06, 2002 3:44 AM
> you are correct on everything. can you help?
Original Message
> From: Randy Knutson
> Todd:
funds. I take it from your email name and your question you are trying to
set up some sort of a display. What types of power levels are you talking
about as far as your amplifiers are concerned? Since these are car radios
and I am assuming car amplifiers you can utilize the 'remote' (blue wire) to
turn them on and off. By doing this you could set up a multiplexer system
using either b.c.d. or SPI. and 32 relays could be eliminated right away. As
far as the speakers are concerned you would need to have some sort of a
switching matrix... I am assuming you are trying to set up a 'best buy'
> -Randy Knutson
> Do You Yahoo!?
At 11:15 AM 6/6/02, you wrote:
>Someone is about to get the axe!
Original Message
>From: "todd's caraudio" <toddscaraudio@m...>
Original Message
> > From: Randy Knutson
> > Todd:
> > -Randy Knutson
> > Do You Yahoo!?
Stephen Swanson
Technical Support Manager
599 Menlo Drive, #100
Rocklin, CA 95765
E-mail:
General Stamp Tech support:
stamptech@p...
Main web site:
www.parallaxinc.com
SX Key website:
www.parallaxinc.com
Education web site:
www.stampsinclass.com
Quit sending multiple messages, 15 to be exactly at the same time, same message.
If you are waiting for your message to showup on the forum it take from 5 to 15
minutes before it will showup.
Thank You !!
Dale Fleischmann
Original Message
> From: Randy Knutson
> Todd:
I take it from your email name and your question you are trying to set up some
> -Randy Knutson
> Do You Yahoo!?
>car amplifiers you can utilize the 'remote' (blue wire) to turn them
on and off. By doing this you could set up a multiplexer system using
How would you do this ? are car radio's controlled via serial
connection to the car's main CPU ? would GM radios all have the same
serial address so they would be interchangeable ? afterall not many
cars have two radios.
Dave
and 32 relays could be eliminated right away. As far as the speakers
are concerned you would need to have some sort of a switching
matrix... I am assuming you are trying to set up a 'best buy' display
> -Randy Knutson
> Do You Yahoo!?
will handle 4 groups of 16 devices each group and there is 8 more data pins
left on the stamp for your use.
norm
see attachment schematic, others who dont see the schematic and want it send
me your private email address and ill send directly, as the stamp list
blocks attachments.
>Reply-To: basicstamps@yahoogroups.com
>Date: Wed, 05 Jun 2002 07:55:25 -0000
>some good help.
>thanks in advance
>todd.
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp.
The blue wire is simply a switch to turn the amplifier on. When you put 12
volts on this wire it turns on a big transistor and the amp comes on. When
you turn your key off it cuts power to this wire and turns the amp off.
This way your main power wire which usually goes straight to the battery and
carries 20 or 30 amps doesn't have to be switched externally its all done
with the little blue wire.
