How Do I Build A Switching System? — Parallax Forums
edited 2002-06-07 15:59 in General Discussion
i would like to build a switching system that will turn on and off 16
car radios, 16 amplifiers, 16 front spekers, 16 rear speakers and 16
sub woofers. i am building a car audio display and would also like to
build my own switching system.
i would also like to control all of the switching from a IR receiver
and transmiter using a sony universal remote.
i need to know what products will be needed as well as a wiring
diagram of how to assemble the stamps and the programing instructions.
this is a real important project to me andi would greatley appriciate
some good help.
i currentley have in my possesion the board of education stamp kit.
i can provide more information if someone has more questions.
thanks in advance
todd.
    edited 2002-06-06 00:14
    And how much are you willing to pay for this TON of work?
    Sent: Wednesday, June 05, 2002 12:55 AM
    Subject: [noparse][[/noparse]basicstamps] How Do I Build A Switching System?
    > some good help.
    > thanks in advance
    > todd.
    edited 2002-06-06 00:17
    GOOD QUESTION!!!
    Don
    Sent: Wednesday, June 05, 2002 4:14 PM
    Subject: Re: [noparse][[/noparse]basicstamps] How Do I Build A Switching System?
    > From: "toddscaraudio2002" <toddscaraudio@m...>
    > > some good help.
    > > thanks in advance
    > > todd.
    and
    edited 2002-06-06 00:50
    I don't think a stamp alone would be capable of such a task. Two
    options I can think of are 3 - 16 position dual contact rotary
    switches. This in itself would probably work. Or you could use 3
    groups of 16 sets of DPDT relays controlled by the stamp which would
    look neater and probably be more expensive. I say DPDT because you would
    probably have to switch the common connection, even though it is
    common. If you know car audio systems, you probably know what I mean.
    Also every K-mart & Walmart has one along with Circuit City. Maybe you
    could ask a question there as well. I think it would be fun to design
    such a thing. Hope this is a start anyway..
    Leroy
    edited 2002-06-06 01:46
    --- In basicstamps@y..., "toddscaraudio2002" <toddscaraudio@m...>
    16
    16
    to
    receiver
    instructions.
    appriciate
    > some good help.
    > thanks in advance
    > todd.
    edited 2002-06-06 01:53
    Hi Todd,
    Are you looking to switch any radio with an speaker and any amp ?
    Once you do the schematic, you may find that simple relays may be the
    cheapest and simplest way to do your switching.
    but 4 sets of 16 units (64 total units) will require quite an
    elaborate set-up.
    if you are just switching things on and off for a showroom style
    display, can all the speakers share a common ground with just the
    positive lead being switched ?
    It seems that the Stamp would be needed only to accept the IR and
    then signal the relays.
    Dave
    16
    16
    to
    receiver
    instructions.
    appriciate
    > some good help.
    > thanks in advance
    > todd.
    edited 2002-06-06 04:01
    do you know how to do it?
    Sent: Wednesday, June 05, 2002 6:17 PM
    > some good help.
    > thanks in advance
    > todd.
    from the same email address that you subscribed. Text in the Subject and Body
    edited 2002-06-06 08:00
    Todd:
    The problem you are trying to solve isn't very hard the main problem is funds. I
    take it from your email name and your question you are trying to set up some
    sort of a display. What types of power levels are you talking about as far as
    your amplifiers are concerned? Since these are car radios and I am assuming car
    amplifiers you can utilize the 'remote' (blue wire) to turn them on and off. By
    doing this you could set up a multiplexer system using either b.c.d. or SPI. and
    32 relays could be eliminated right away. As far as the speakers are concerned
    you would need to have some sort of a switching matrix... I am assuming you are
    trying to set up a 'best buy' display system. Am I correct?
    -Randy Knutson
    Do You Yahoo!?
    Sign-up for Video Highlights of 2002 FIFA World Cup
    edited 2002-06-06 09:44
    you are correct on everything. can you help?
    Sent: Thursday, June 06, 2002 1:58 AM
    Todd:
    -Randy Knutson
    Do You Yahoo!?
    Todd:
    -Randy Knutson
    Do You Yahoo!?
    Todd:
    -Randy Knutson
    Do You Yahoo!?
    edited 2002-06-06 14:32
    Try a search on "crosspoint switches". These do a neat "any-to-any" signal
    connection and can easily be controlled by a Stamp. They are typically
    used in video systems and you "might" be able to pick up a freebie. I have
    no idea about the power/frequency specs, but it might be something to check
    on.
    As for the bushel of relays option, there are many related messages in the
    archives.
    Good luck.
    > some good help.
    > thanks in advance
    > todd.
    The information transmitted is intended only for the person
    or entity to which it is addressed and may contain confidential
    and/or privileged material. If you are not the intended recipient
    of this message you are hereby notified that any use, review,
    retransmission, dissemination, distribution, reproduction or any
    action taken in reliance upon this message is prohibited. If you
    received this in error, please contact the sender and delete the
    material from any computer. Any views expressed in this message
    are those of the individual sender and may not necessarily reflect
    the views of the company.
    edited 2002-06-06 19:15
    Someone is about to get the axe!
    Sent: Thursday, June 06, 2002 3:44 AM
    > From: Randy Knutson
    > Todd:
    funds. I take it from your email name and your question you are trying to
    set up some sort of a display. What types of power levels are you talking
    about as far as your amplifiers are concerned? Since these are car radios
    and I am assuming car amplifiers you can utilize the 'remote' (blue wire) to
    turn them on and off. By doing this you could set up a multiplexer system
    using either b.c.d. or SPI. and 32 relays could be eliminated right away. As
    far as the speakers are concerned you would need to have some sort of a
    switching matrix... I am assuming you are trying to set up a 'best buy'
    > -Randy Knutson
    > Do You Yahoo!?
    edited 2002-06-06 19:21
    we are looking in to it right now
    >From: "todd's caraudio" <toddscaraudio@m...>
    > > From: Randy Knutson
    > > Todd:
    > > -Randy Knutson
    > > Do You Yahoo!?
    Stephen Swanson
    Technical Support Manager
    599 Menlo Drive, #100
    Rocklin, CA 95765
    E-mail:
    General Stamp Tech support:
    stamptech@p...
    Main web site:
    www.parallaxinc.com
    SX Key website:
    www.parallaxinc.com
    Education web site:
    www.stampsinclass.com
    edited 2002-06-07 07:06
    Hi Todd;
    Quit sending multiple messages, 15 to be exactly at the same time, same message.
    If you are waiting for your message to showup on the forum it take from 5 to 15
    minutes before it will showup.
    Thank You !!
    Dale Fleischmann
    > From: Randy Knutson
    > Todd:
    I take it from your email name and your question you are trying to set up some
    > -Randy Knutson
    > Do You Yahoo!?
    edited 2002-06-07 13:26
    --- In basicstamps@y..., Randy Knutson <ken_ryder@y...> wrote:
    >car amplifiers you can utilize the 'remote' (blue wire) to turn them
    on and off. By doing this you could set up a multiplexer system using
    How would you do this ? are car radio's controlled via serial
    connection to the car's main CPU ? would GM radios all have the same
    serial address so they would be interchangeable ? afterall not many
    cars have two radios.
    Dave
    and 32 relays could be eliminated right away. As far as the speakers
    are concerned you would need to have some sort of a switching
    matrix... I am assuming you are trying to set up a 'best buy' display
    > -Randy Knutson
    > Do You Yahoo!?
    edited 2002-06-07 14:08
    here is a schematic for a nice unit, u can add any input device you need, id
    will handle 4 groups of 16 devices each group and there is 8 more data pins
    left on the stamp for your use.
    norm
    see attachment schematic, others who dont see the schematic and want it send
    me your private email address and ill send directly, as the stamp list
    blocks attachments.
    >Reply-To: basicstamps@yahoogroups.com
    >Date: Wed, 05 Jun 2002 07:55:25 -0000
    >some good help.
    >thanks in advance
    >todd.
    _________________________________________________________________
    Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp.
    The blue wire is simply a switch to turn the amplifier on. When you put 12
    volts on this wire it turns on a big transistor and the amp comes on. When
    you turn your key off it cuts power to this wire and turns the amp off.
    This way your main power wire which usually goes straight to the battery and
    carries 20 or 30 amps doesn't have to be switched externally its all done
    with the little blue wire.
