Averaging routine
Does any one have a good routine that will mimmic a true floating
point average. One that gives a result that could be output to a seec
serial lcd display?
Beating my head aginst the wall - please help before I get yelled at
for putting dents in the drywall. [noparse]:)[/noparse]
serial lcd display?
The Basic Stamp does not do floating point math. If you can multiple all
your numbers before adding them then
dividing them by the total numbers you use, and then divide this result by what
you multiplied all the numbers by
you will get an integer value close to, but not quite the floating point value
you want. Others will give you
more details on how to do this better, I only started to learn about Basic
Stamps a short time age. Look at past
posts about floating point math, if you do not get any response soon.
Have Fun !!
Dale Fleischmann
> serial lcd display?
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
bit word. For example, suppose you want to find the average of 34 50 21
and 40. Multiply each number by 10 FIRST. So you have:
340+500+210+400 = 1450
Now you can divide by 4 to get 362
The correct answer is 36.2
Well... It is really 36.25, but you only "asked" for one digit of
precision. OK, so you want two digits. Multiply by 100:
3400 + 5000 + 2100 + 4000 = 14500
/4 = 3625
But don't get carried away. As soon as one of your numbers multiplied by
your scaling factor goes over 65535 you are out of luck.
If you really want to do this in floating point check out the PAK-I, II,
and IX coprocessors. They do 32-bit floating point. The PAK-IX even has
a multichannel A/D and can read an average of a channel automatically.
http://www.al-williams.com/awce/pak1.htm
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
Original Message
> From: Dale Fleischmann [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hmnlYMSMpv2NabwCsomnhZywR4iFXCXcyhDp4Adwd9v6WTWAI2lHFFs_U-zQ0CuhYAdovx3U65gUh6w]fleidale@c...[/url
> Sent: Thursday, May 30, 2002 12:32 AM
> To: basicstamps@yahoogroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] Averaging routine
> Hi;
> can multiple all your numbers before adding them then
> this result by what you multiplied all the numbers by you
> floating point value you want. Others will give you more
> about Basic Stamps a short time age. Look at past posts
> Have Fun !!
> Dale Fleischmann
> to a seec
> > serial lcd display?
> yelled at
> the Subject
> > and Body of the message will be ignored.
> Subject and Body of the message will be ignored.
>serial lcd display?
I have a routine for calculating the mean and standard deviation of
data from a 12-bit converter posted at
http://www.emesys.com/BS2math5.htm#Statistics
It is a double precision (32 bit) integer routine, as both the sum of
values and especially the sum of the squares become quite large.
The mean and SD will also be 12 bit values, so they can be displayed
on the serial display using the standard DEC modifier.
-- best regards
Tracy Allen
electronically monitored ecosystems
http://www.emesystems.com
mailto:tracy@e...
