Averaging routine — Parallax Forums
Averaging routine
edited 2002-05-30 20:35 in General Discussion
Does any one have a good routine that will mimmic a true floating
point average. One that gives a result that could be output to a seec
serial lcd display?
Beating my head aginst the wall - please help before I get yelled at
for putting dents in the drywall. [noparse]:)[/noparse]
    edited 2002-05-30 06:32
    Hi;
    The Basic Stamp does not do floating point math. If you can multiple all
    your numbers before adding them then
    dividing them by the total numbers you use, and then divide this result by what
    you multiplied all the numbers by
    you will get an integer value close to, but not quite the floating point value
    you want. Others will give you
    more details on how to do this better, I only started to learn about Basic
    Stamps a short time age. Look at past
    posts about floating point math, if you do not get any response soon.
    Have Fun !!
    Dale Fleischmann
    > serial lcd display?
    edited 2002-05-30 13:14
    You may consider a fixed point solution if your numbers will fit in a 16
    bit word. For example, suppose you want to find the average of 34 50 21
    and 40. Multiply each number by 10 FIRST. So you have:
    340+500+210+400 = 1450
    Now you can divide by 4 to get 362
    The correct answer is 36.2
    Well... It is really 36.25, but you only "asked" for one digit of
    precision. OK, so you want two digits. Multiply by 100:
    3400 + 5000 + 2100 + 4000 = 14500
    /4 = 3625
    But don't get carried away. As soon as one of your numbers multiplied by
    your scaling factor goes over 65535 you are out of luck.
    If you really want to do this in floating point check out the PAK-I, II,
    and IX coprocessors. They do 32-bit floating point. The PAK-IX even has
    a multichannel A/D and can read an average of a channel automatically.
    http://www.al-williams.com/awce/pak1.htm
    Al Williams
    AWC
    * Control 8 servos at once
    http://www.al-williams.com/awce/pak8.htm
    > From: Dale Fleischmann [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hmnlYMSMpv2NabwCsomnhZywR4iFXCXcyhDp4Adwd9v6WTWAI2lHFFs_U-zQ0CuhYAdovx3U65gUh6w]fleidale@c...[/url
    > Sent: Thursday, May 30, 2002 12:32 AM
    > Subject: Re: [noparse][[/noparse]basicstamps] Averaging routine
    > Hi;
    > can multiple all your numbers before adding them then
    > this result by what you multiplied all the numbers by you
    > floating point value you want. Others will give you more
    > about Basic Stamps a short time age. Look at past posts
    > Have Fun !!
    > Dale Fleischmann
    > to a seec
    > > serial lcd display?
    > yelled at
    > the Subject
    > > and Body of the message will be ignored.
    >serial lcd display?
    I have a routine for calculating the mean and standard deviation of
    data from a 12-bit converter posted at
    http://www.emesys.com/BS2math5.htm#Statistics
    It is a double precision (32 bit) integer routine, as both the sum of
    values and especially the sum of the squares become quite large.
    The mean and SD will also be 12 bit values, so they can be displayed
    on the serial display using the standard DEC modifier.
    -- best regards
    Tracy Allen
    http://www.emesystems.com
    mailto:tracy@e...
