x-10 question
Hi, I am trying my hands at X-10 in combination with the Basic Stamp (bs2e)
for the first time (as far as X-10 is concerned) and seem to have some
communication problems with the interface. I live in Europe, so the AC
power cycle is 50 Hz, and the X-10 modules I use have been bought here and
are intended to operate at 50 Hz. The set up I use for testing is Bs2e,
activity board, XM10E (Powerhouse) two way TTL/CMOS interface (basically
the same as TW-523, according to the limited technical references and
schematics) and LM12 Lamp Module. And...nothing happens (with the simple
test program from the stamp manual). It's the first time I encounter such a
radical problem with the stamp. So I wonder if it could have something to
do with the power cycle, that somehow the basic stamp is meant to function
with 60Hz X-10 appliances, this doesn't really make sense to me as all the
stamp does is sending data, the power configuration is an X-10 matter...or
am I missing something here?
Guy
http://www.guydebievre.de.vu
Guy
the PL-513 and the TW-523. No mention of the XM10E.
There is also an Ap Note on the X10:
http://www.parallaxinc.com/downloads/Documentation/Basic%20Stamps/BASIC%20St
amp%202%20App%20Notes%20v1.9.pdf
See pg 2 for a schematic on interfacing with the modules.
(bs2e)
a
> Guy
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
http://wd5gnr.virtualave.net/cgi-bin/TWiki/view.pl/Main/FireCracker
Use user ID=GuestUser, password=guest
This provider has been restricting our bandwidth lately, so if you get
an over limit message, just try again.
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
Original Message
> From: Guy De Bi
thanks for trying to help, but no, I have no Firecracker (I don't think you
can get it in Europe) and I do have the Stamp manual mentioning the PL513
and TW523, but it doesn't exclude other models, and according to the specs
the XM10 is just a follow up with similar configuration, and definitely
similar protocol. I guess I go on tring and I will bug the manufacturer
some more and in the end will have to address the thing directly.
Guy
At 00:20 28/05/02 +0000, you wrote:
> From: Rodent <daweasel@s...>
>Subject: Re: x-10 question
>According to the Stamp Manual version 2.0c, the only supported modules are
> From: "Al Williams" <alw@a...>
>Subject: RE: x-10 question
>If you have the cheap "firecracker" module, you might find this helpful:
