x-10 question — Parallax Forums
x-10 question
edited 2002-05-28 21:25 in General Discussion
Hi, I am trying my hands at X-10 in combination with the Basic Stamp (bs2e)
for the first time (as far as X-10 is concerned) and seem to have some
communication problems with the interface. I live in Europe, so the AC
power cycle is 50 Hz, and the X-10 modules I use have been bought here and
are intended to operate at 50 Hz. The set up I use for testing is Bs2e,
activity board, XM10E (Powerhouse) two way TTL/CMOS interface (basically
the same as TW-523, according to the limited technical references and
schematics) and LM12 Lamp Module. And...nothing happens (with the simple
test program from the stamp manual). It's the first time I encounter such a
radical problem with the stamp. So I wonder if it could have something to
do with the power cycle, that somehow the basic stamp is meant to function
with 60Hz X-10 appliances, this doesn't really make sense to me as all the
stamp does is sending data, the power configuration is an X-10 matter...or
am I missing something here?
Guy
http://www.guydebievre.de.vu
    edited 2002-05-27 20:38
    According to the Stamp Manual version 2.0c, the only supported modules are
    the PL-513 and the TW-523. No mention of the XM10E.
    There is also an Ap Note on the X10:
    http://www.parallaxinc.com/downloads/Documentation/Basic%20Stamps/BASIC%20St
    amp%202%20App%20Notes%20v1.9.pdf
    See pg 2 for a schematic on interfacing with the modules.
    (bs2e)
    a
    > Guy
    edited 2002-05-27 21:10
    If you have the cheap "firecracker" module, you might find this helpful:
    http://wd5gnr.virtualave.net/cgi-bin/TWiki/view.pl/Main/FireCracker
    Use user ID=GuestUser, password=guest
    This provider has been restricting our bandwidth lately, so if you get
    an over limit message, just try again.
    Al Williams
    AWC
    * 8 channels of PWM
    http://www.al-williams.com/awce/pak5.htm
    > From: Guy De Bi
    thanks for trying to help, but no, I have no Firecracker (I don't think you
    can get it in Europe) and I do have the Stamp manual mentioning the PL513
    and TW523, but it doesn't exclude other models, and according to the specs
    the XM10 is just a follow up with similar configuration, and definitely
    similar protocol. I guess I go on tring and I will bug the manufacturer
    some more and in the end will have to address the thing directly.
    Guy
    At 00:20 28/05/02 +0000, you wrote:
    > From: Rodent <daweasel@s...>
    >Subject: Re: x-10 question
    > From: "Al Williams" <alw@a...>
    >Subject: RE: x-10 question
