Circuit Simulation Software
Hi all,
does anyone know of any good Circuit Simulation sofware, both A and D?
Please email me at rilyasov@n... with any info.
I greately appreciate it!
Thank you.
Thank you.
>Hi all,
The Piclist members have been talking about this very subject lately. The
general consensus is that the FREE package offered by Linear Technology is
excellent. The package is called Switcher CAD III and can be downloaded
from <http://www.linear-tech.com/software/>. Its a 2.8 Mb download and
includes a decent schematic entry package as well.
The libraries and SPICE models can be added to at will: there appears to be
no problem adding parts from NS and other semi manufacturers.
I have played with it but have not developed any expertise with it
(yet). But it is free for the cost of a download and is well worth
checking out.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
I also looking for a circuit simulation softwear A and D with pcb placement.
If anyone knowes please e-mail to the basicstamps group.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, April 29, 2002 11:31 PM
Subject: [noparse][[/noparse]basicstamps] Circuit Simulation Software
> Hi all,
> Thank you.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
simulator with enhancements and models for easing the simulation of
switching regulators" is nice if you're designing a switching power supply
(with LTC parts) but it doesn't do much else.
Try this link: http://www.audioscientific.com/Circuit%20Simulators.htm for a
few ideas on low cost and/or free analog and digital circuit analysis tools.
Original Message
Sent: Monday, April 29, 2002 10:32 PM
Subject: Re: [noparse][[/noparse]basicstamps] Circuit Simulation Software
> At 05:31 PM 4/29/02 +0000, riccello wrote:
> >Hi all,
be
> checking out.
> dwayne
From what I have seen, it appears to quite nicely simulate much more than
just switch mode power supplies. I'm not suggesting that it should be the
only tool one should use - quite the opposite.
But the question was: "where can I find a free simulation program". Not
only does SwitcherCAD meet that requirement, it is supported by a major
manufacturer and updated frequently. Linear Technology appears to do a
build on average once a week - just keep track of the file date on the
download page.
In addition to being a reasonable simulation package, it contains a
kick-*** schematic entry module. The package is worth the download just
for that.
dwayne
Quote from Linear Technology's download page:
"Included in this download are Spice, Macro Models for 80% of Linear
Technology's switching regulators and over 200 op amp models. Furthermore,
resistors, transistors and MOSFET models are included as part of this
package. With this Spice simulation, viewing of the waveforms of most
switching regulators can be achieved in a few minutes on a high performance
PC. Also, full circuits using op amps or transistors can easily be simulated."
Notice the last sentence in the above quote.
Quotes from several Piclist members:
I'd recommend LT SwitcherCad which despite the name, is a full spice
implementation. Plus, it really does switchers nicely too. I've mentioned
this program several times of late and someone might well get the
impression that I'm recommending it in place of circuit testing with real
parts. It is a very good tool to try out many ideas and see which ones look
promising.
And you can download other spice models from other manufacturers and use
them. For example, I downloaded a LF411 op amp from National, then modified
a basic op-amp "symbol" that LTC provided to use the LF411 model and
presto! It works.
>How do you add other manufacturer's models to SwitcherCAD?
I downloaded the LF411 SPICE model from National.
Then I copied the "opamp2.asy" symbol and renamed it 'lf411.asy"
Made the following changes in the lf411.asy file(changed the two lines to
read as follows - note that in the SPICE model file the LF411 is actually
named LF411/NS):
SYMATTR SpiceModel LF411/NS
SYMATTR Value LF411/NS
Finally, you need to add the following SPICE command to your SwCad simulation
.lib LF411.sub
To amplify on Daves response, I *have* used SwitcherCAD III. I have two
things to say about it:
1. It correctly predicted how LT's switching power supply parts would work
in circuit. My scope waveforms looked like those on the PC.
2. It is indeed a "full" spice version and it seems to work quite well. I
built a few state variable oscillators and it produced the output I expected.
Plus, as Dave said, "The price is right, for sure".
It was possible to confuse it until it gave poor output (probably was not
converging) but this is typical of any spice. It requires the user to know
what they are doing and not just blindly accept what it says. Doh!
I just downloaded it a month ago and found I like it a lot. I had tried it
years ago and did not like it. I suspect both it and I have matured. OK,
maybe just it matured.
> I tried to simulate the 2 transistor circuit Roman published to the
>list a while ago and I was not able to make it oscilate under switchCad
>spice simulator ! Is there any tricks the can be made to make it work in
>simulation ? I am absolutely sure it works in practice :-)
Open the tools->SPICE and set the max timestep to at most 1/20 of the
expected osc. period. F.ex. for 100kHz max expected osc. freq. set 5e-7
This is true for any .tran analysis in any spice program I know of.
Peter
At 11:07 PM 4/29/02 -0500, Tom Hendrick wrote:
>Switcher Cad III - "LTC SwitcherCADT III is a fully functional Spice III
Original Message
>From: "Dwayne Reid" <dwayner@p...>
> > >Hi all,
>be
> > checking out.
> > dwayne
desired. It is also capable of adding PCB layout autorouting etc. It isn't
free but is great for beginners and technician level hobbyists, but also has
features required by Engineering professionals. It used to be called
Electronics workbench.
with any other (cheaper) packages, or if there are any other PCB
applications that can work with Protel files ?
Justin.
Original Message
From: azeasi@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z_NdRQDT8rd0dozqbvwXZwhMcCoJV2jD48tEeZiOHqjuGph-CRZJp9lIonxr7LNAGUhA-NINkJXD]azeasi@a...[/url
Sent: 01 May 2002 14:52
To: basicstamps@yahoogroups.com
MultiSim 2001 (2002?) is a good low cost package that can be expanded as
CircuitMaker works with Protel. It is their lower cost package that
includes TraxMaker.
http://www.circuitmaker.com/
David
Original Message
Sent: Wednesday, May 01, 2002 7:06 AM
Subject: RE: [noparse][[/noparse]basicstamps] Circuit Simulation Software
> As a side issue, does anyone know if Protel files can be converted to work
> Regards,
> Justin.
Original Message
> From: azeasi@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=G1i8df4jXbc_B8wCr8Ntga5hXCI94aENzSBV3YjkQe0xNW4fJ7Gs5hZ1pvYsZ5KvA8xEdw]azeasi@a...[/url
has
I just downloaded their trial version, now to see if I can justify the $995
price tag !
Justin.
Original Message
From: David Covick [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SOfqvnSdKeFg1w6pTiny3ZKW-ZyxIC-S895HCbFzxzMJ5oQrPmAkRahnu4ZoKyyo5u8]dac@w...[/url
Sent: 01 May 2002 15:12
Justin,
includes TraxMaker.
David
Original Message
> Regards,
> Justin.
Original Message
> From: azeasi@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=K-Hmtu2h0D56Aq4a0cpGa5g9KU9Z-9SMFNXKeb1q9T8qo1j0e5diM1r0aFZ7JyD_hP38oFoEXDZ0]azeasi@a...[/url
has
