IR badges
Hello BX-24ers,
I'm making a small infrared emitter badge to register badge location in
a space with distributed IR detectors. The badges consist of the BX-24,
an IR LED, and powersource.
Each badge needs a unique IR pulse rate.
Can anyone suggest some simple BX24 code that I could play with to get
unique pulse rates for each badge I build?
Many thanks
Robert
Many thanks
Robert
all the receivers will be the same just send out different ID
Like a sony IR remote for a TV,VCR.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: April 23, 2002 5:45 PM
Subject: [noparse][[/noparse]basicstamps] IR badges
Hello BX-24ers,
location in
BX-24,
to get
Many thanks
Robert
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the
Subject and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
transmitted on a set modulation.
http://dbserv.maxim-ic.com/quick_view2.cfm?qv_pk=2903
-Rob
Original Message
Sent: Tuesday, April 23, 2002 8:45 PM
> Hello BX-24ers,
> Many thanks
> Robert
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> How about not changing the pulse rate and use standard 40khz so
This is sort of related, does anyone have any solutions for using a
basic stamp to control a VCR. eg acting as a IR remote ?
Cheers
Robin
Original Message
> From: "Robert RJC Whelan" <rrw216@n...>
> Hello BX-24ers,
> location in
> BX-24,
> to get
> Many thanks
> Robert
resolution ought to be plenty fast enough. When I asked about this
earlier, I was immediately flamed with disbelievers that say it's not
possible. I don't think the stamp would be able to create the 40 khz
carrier, but I believe it could modulate that carrier created with an
external oscillator with the info from this link. Here's a link a found
on the subject that is cryptic, but seems to contain a lot of good
info. If I could just figure out what the bit stream is and use it to
modulate a 40 Khz or so IR carrier, I think it might work. Course, I am
not an engineer by trade I am an electronics Technician / Instructor.
Here's the link, would appreciate any data you come up with:
http://www.geocities.com/SiliconValley/Lakes/3947/infrared.htm
Leroy
Robin Petterd wrote:
> Hi all,
> Cheers
> Robin
Original Message
> > Hello BX-24ers,
> > location in
> > BX-24,
> > to get
> > Many thanks
> > Robert
> from the same email address that you subscribed. Text in the Subject and Body
