IR badges — Parallax Forums
IR badges
edited 2002-04-25 06:27 in General Discussion
Hello BX-24ers,
I'm making a small infrared emitter badge to register badge location in
a space with distributed IR detectors. The badges consist of the BX-24,
an IR LED, and powersource.
Each badge needs a unique IR pulse rate.
Can anyone suggest some simple BX24 code that I could play with to get
unique pulse rates for each badge I build?
Many thanks
Robert
    edited 2002-04-24 01:55
    How about not changing the pulse rate and use standard 40khz so
    all the receivers will be the same just send out different ID
    Like a sony IR remote for a TV,VCR.
    Sent: April 23, 2002 5:45 PM
    Subject: [noparse][[/noparse]basicstamps] IR badges
    Hello BX-24ers,
    location in
    BX-24,
    to get
    Many thanks
    Robert
    from the same email address that you subscribed. Text in the
    Subject and Body of the message will be ignored.
    Your use of Yahoo! Groups is subject to
    edited 2002-04-24 04:02
    Go with a Dallas Semiconductor one-wire silicon serial number (DS2401)
    transmitted on a set modulation.
    http://dbserv.maxim-ic.com/quick_view2.cfm?qv_pk=2903
    -Rob
    Sent: Tuesday, April 23, 2002 8:45 PM
    > Hello BX-24ers,
    > Many thanks
    > Robert
    edited 2002-04-25 05:08
    Hi all,
    This is sort of related, does anyone have any solutions for using a
    basic stamp to control a VCR. eg acting as a IR remote ?
    Cheers
    Robin
    > From: "Robert RJC Whelan" <rrw216@n...>
    > Hello BX-24ers,
    > location in
    > BX-24,
    > to get
    > Many thanks
    > Robert
    I don't see why this could not be done with pulse out. A 2 usec
    resolution ought to be plenty fast enough. When I asked about this
    earlier, I was immediately flamed with disbelievers that say it's not
    possible. I don't think the stamp would be able to create the 40 khz
    carrier, but I believe it could modulate that carrier created with an
    external oscillator with the info from this link. Here's a link a found
    on the subject that is cryptic, but seems to contain a lot of good
    info. If I could just figure out what the bit stream is and use it to
    modulate a 40 Khz or so IR carrier, I think it might work. Course, I am
    not an engineer by trade I am an electronics Technician / Instructor.
    Here's the link, would appreciate any data you come up with:
    http://www.geocities.com/SiliconValley/Lakes/3947/infrared.htm
    Leroy
    Robin Petterd wrote:
    > Hi all,
    > Cheers
    > Robin
    > > Hello BX-24ers,
    > > location in
    > > BX-24,
    > > to get
    > > Many thanks
    > > Robert
