keyboard interface
Hi guys
Anyone have the pinout and information on the keyboard interface for
a PC?
Jody
a PC?
Jody
(on page 3).
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
Original Message
> From: moparjody [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2AB-xG12wI612smKNjpIQPjHVUfk3sJTANhuTJb2Nt2XRzJXt92IGsg9RCgv2fuGoBc5T53FXIYRA5gVHKz_RQ]jody.gallant@s...[/url
> Sent: Sunday, April 21, 2002 7:57 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] keyboard interface
> Hi guys
> a PC?
> Thanks
> Jody
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
http://www.ee.surrey.ac.uk/Personal/A.Gale/sam/keyb.gif
Leroy
moparjody wrote:
> Hi guys
> a PC?
> Thanks
> Jody
> from the same email address that you subscribed. Text in the Subject and Body
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
will help, but I will explain exactly what I want to do.
I want to install a stamp unit, between a PC keyboard and the PC.
There will also be a second device, not a keyboard, that will be
used to simulate a group of keystrokes under certain circumstances.
Anyone who has seen a keyboard wedge for a barcode scanner, it will
be similar to this. Basically when the user presses certain keys on
this second device,it will send a sequence of Keys. (ie F4, F3,
etc..) At the same time, the keyboard can still be used.
As I understand, and correct me if I am wrong, the keyboard sends
synchronous data that is clocked out the data pin via the clock
signal. I should be able to clock this in with the stamp, and clock
it out set of pins. Does this sound correct?
Thanks for all the help.
Jody
--- In basicstamps@y..., Leroy Hall <leroy@f...> wrote:
> See if the following is what you are looking for:
> Leroy
> moparjody wrote:
> > Hi guys
for
> > a PC?
> > Thanks
> > Jody
> > basicstamps-unsubscribe@y...
>I will have to look through both of the suggestions to see if they
>Jody
>Jody -
Here is a link to a PC Keyboard FAQ. It should give you all the information
you are seeking in terms of timing and protocol:
http://www.repairfaq.org/filipg/LINK/PORTS/F_Keyboard_FAQ.html
Bruce Bates
something that will mimic pressing keys on a keyboard so I can mount one or
two buttons on a test fixture and not have to deal with a whole keypad.
As far as what you want to do, a Microsoft Strategic Commander or similar
game controller may be a better deal. It will record and playback keystrokes
when a button is pressed. It is USB though.
Original Message
