MS Mouse emulator
Hello all,
I am trying to emulate the left click of a mouse. I basically only want to get
Power Point slides to advance, when a pulse is detected on an I/O port (I got a
plate with button/led manufactured, and I am mounting that in a podium... 50'
away from the computer)
I am wondering if any of you have done this in the past. If you can give me the
handshake procedure between the mouse/PC, and the code to send for left click, I
can probably figure out the programming (although this will be my first
programming project)
(I have purchased a Stamp II)
Thanks in advance for any help.
Martin Menard
Martin Menard
http://www.wd5gnr.com/rfrem.htm.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
Original Message
> From: Martin Menard [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mcG_tkmbRgOWvAvYsNJBhL9M1RjiIotqqoRYDGboed5c_CuTXQ9B4FRv21Ja6cjbj2ByDOGuhJoaN83BfGc]marty6000@h...[/url
> Sent: Saturday, April 20, 2002 8:32 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] MS Mouse emulator
> Hello all,
> basically only want to get Power Point slides to advance,
> when a pulse is detected on an I/O port (I got a plate with
> podium... 50' away from the computer)
> you can give me the handshake procedure between the mouse/PC,
> and the code to send for left click, I can probably figure
> Martin Menard
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
>Hello all,
>to get Power Point slides to advance, when a pulse is detected on an I/O
>port (I got a plate with button/led manufactured, and I am mounting that
>in a podium... 50' away from the computer)
>me the handshake procedure between the mouse/PC, and the code to send for
>left click, I can probably figure out the programming (although this will
>be my first programming project)
>Martin Menard
Here is something that I did a few years ago. Go to the link below and select
"MicroSoft MOUSE emulator". There you will find schematics and code, etc...
that should help you out.
http://home.earthlink.net/~y2kbc/Electronics/BasicStamp/Index.html
Beau Schwabe Mask Designer IV - ATL
National Semiconductor Enterprise Networking Business Unit
500 Pinnacle Court, Suite 525 Wired Communications Division
Mail Stop GA1 Norcross, GA 30071
I suggest that you simply use a hacked mouse near the PC with a shielded
cable connected one side to the mouse button and the other side to the
podium button.
I did not try it for a 50' distance but it is worth a inexpensive test.
Regards
ECO
> At 09:31 PM 4/20/02 -0400, you wrote:
> Hello all,
> Martin Menard
