MS Mouse emulator — Parallax Forums
MS Mouse emulator
edited 2002-04-23 10:15 in General Discussion
Hello all,
I am trying to emulate the left click of a mouse. I basically only want to get
Power Point slides to advance, when a pulse is detected on an I/O port (I got a
plate with button/led manufactured, and I am mounting that in a podium... 50'
away from the computer)
I am wondering if any of you have done this in the past. If you can give me the
handshake procedure between the mouse/PC, and the code to send for left click, I
can probably figure out the programming (although this will be my first
programming project)
(I have purchased a Stamp II)
Thanks in advance for any help.
Martin Menard
    edited 2002-04-21 04:55
    Not exactly what you want, but I have a power point clicker project at
    http://www.wd5gnr.com/rfrem.htm.
    Al Williams
    AWC
    * Floating point A/D
    http://www.al-williams.com/awce/pak9.htm
    > From: Martin Menard [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mcG_tkmbRgOWvAvYsNJBhL9M1RjiIotqqoRYDGboed5c_CuTXQ9B4FRv21Ja6cjbj2ByDOGuhJoaN83BfGc]marty6000@h...[/url
    > Sent: Saturday, April 20, 2002 8:32 PM
    > Subject: [noparse][[/noparse]basicstamps] MS Mouse emulator
    > Hello all,
    > basically only want to get Power Point slides to advance,
    > when a pulse is detected on an I/O port (I got a plate with
    > podium... 50' away from the computer)
    > you can give me the handshake procedure between the mouse/PC,
    > and the code to send for left click, I can probably figure
    > Martin Menard
    > from the same email address that you subscribed. Text in the
    edited 2002-04-22 18:45
    At 09:31 PM 4/20/02 -0400, you wrote:
    >Hello all,
    >to get Power Point slides to advance, when a pulse is detected on an I/O
    >port (I got a plate with button/led manufactured, and I am mounting that
    >in a podium... 50' away from the computer)
    >me the handshake procedure between the mouse/PC, and the code to send for
    >left click, I can probably figure out the programming (although this will
    >be my first programming project)
    >Martin Menard
    Here is something that I did a few years ago. Go to the link below and select
    "MicroSoft MOUSE emulator". There you will find schematics and code, etc...
    that should help you out.
    http://home.earthlink.net/~y2kbc/Electronics/BasicStamp/Index.html
    Beau Schwabe Mask Designer IV - ATL
    National Semiconductor Enterprise Networking Business Unit
    500 Pinnacle Court, Suite 525 Wired Communications Division
    Mail Stop GA1 Norcross, GA 30071
    Martin
    I suggest that you simply use a hacked mouse near the PC with a shielded
    cable connected one side to the mouse button and the other side to the
    podium button.
    I did not try it for a 50' distance but it is worth a inexpensive test.
    Regards
    ECO
    > Hello all,
    > Martin Menard
