LED Drivers - UCN5833A
I need to drive 3" CC LED 7-seg displays (4 digists). This IC seems
to fit the bill perfectly. Has anyone used it? Any feedback?
thanks
Al Najjar
thanks
Al Najjar
Have not used that chip but have used the MAX7219, which will drive 8 digits.
Seems to work very well. Requires 3 inputs, data, load and clock.
Sid
voltage nor current required by my display. Which means that I will
have to add some source drivers to the circuit that will complicate
life for me....
--- In basicstamps@y..., Newzed@a... wrote:
> For Al
drive 8 digits.
> Sid
>The problem however is that the MAX7219 would not provide that
>life for me....
Can you use common anode displays? If so, the TPIC6595 is a great little
driver chip. They cascade easily so that you need only 3 lines from the
Stamp and each output can sink 250 mA / 50 Vdc. But they are sinking
outputs only.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
Volts @ 100mA per line.. let me know..
brownstamp <brownstamp@y...> wrote: The problem however is that the
life for me....
> For Al
drive 8 digits.
> Sid
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Do You Yahoo!?
Yahoo! Games - play chess, backgammon, pool and more
