LED Drivers - UCN5833A — Parallax Forums
edited 2002-04-21 01:46 in General Discussion
I need to drive 3" CC LED 7-seg displays (4 digists). This IC seems
to fit the bill perfectly. Has anyone used it? Any feedback?
thanks
Al Najjar
    edited 2002-04-19 20:32
    For Al
    Have not used that chip but have used the MAX7219, which will drive 8 digits.
    Seems to work very well. Requires 3 inputs, data, load and clock.
    Sid
    edited 2002-04-19 21:37
    The problem however is that the MAX7219 would not provide that
    voltage nor current required by my display. Which means that I will
    have to add some source drivers to the circuit that will complicate
    life for me....
    --- In basicstamps@y..., Newzed@a... wrote:
    > For Al
    drive 8 digits.
    > Sid
    edited 2002-04-19 23:34
    >life for me....
    Can you use common anode displays? If so, the TPIC6595 is a great little
    driver chip. They cascade easily so that you need only 3 lines from the
    Stamp and each output can sink 250 mA / 50 Vdc. But they are sinking
    outputs only.
    dwayne
    Dwayne Reid <dwayner@p...>
    Trinity Electronics Systems Ltd Edmonton, AB, CANADA
    (780) 489-3199 voice (780) 487-6397 fax
    Celebrating 18 years of Engineering Innovation (1984 - 2002)
    Do NOT send unsolicited commercial email to this email address.
    This message neither grants consent to receive unsolicited
    commercial email nor is intended to solicit commercial email.
    How much current do you need per line? I just built a working driver for 8
    Volts @ 100mA per line.. let me know..
    brownstamp <brownstamp@y...> wrote: The problem however is that the
    life for me....
    > For Al
    drive 8 digits.
    > Sid
    from the same email address that you subscribed. Text in the Subject and Body of
    the message will be ignored.
    Do You Yahoo!?
    Yahoo! Games - play chess, backgammon, pool and more
