Trouble with connection a basic stamp to pc
Hi,
i want to connect a basic stamp II with my pc. I use
basic stamp 1.3 editor. The debug test work properly,
but when i download the program thi message appare:
"Hardware connection failure! Check Serial
cable and power supply."
I check the power supply and it's good, and also the
serial cable. The serial connection of my pc work
properly (i connect with a modem for a test)
does someone have the same problem ?
does someone have idea of how to fix ?
thanks for all.
Riccardo Fanetti.
__________________________________________________
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
http://taxes.yahoo.com/
thanks for all.
Riccardo Fanetti.
Do You Yahoo!?
Are you using an experimenter board or a home brew pc board on your project?
Is it an experimenter board made for the Basic Stamp or one of the many after
market boards available?
If it is a home brew pc board or after market board are pins 6 and 7 connected
together on the connector?
Note, some after market boards do not connect pins 6 and 7 together.
Hope this will help !!
Dale Fleischmann
Riccardo Fanetti wrote:
> Hi,
> thanks for all.
> Riccardo Fanetti.
> Do You Yahoo!?
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Dale mentioned after market boards. All of ours have the correct
connections, but I can't speak for any others.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
Original Message
> From: Dale Fleischmann [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zP5t8plGBFsI4GD2tEbvNUSD59M03X2pcCY2t8fdzgdo3uXZLIz6q6oAysW0lcQmzXYYh2SoecT5zu0iDr5S]fleidale@c...[/url
> Sent: Tuesday, April 16, 2002 2:33 PM
> To: basicstamps@yahoogroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] Trouble with connection a basic stamp to pc
> Hi Riccardo Fanetti,
> board on your project? Is it an experimenter board made for
> the Basic Stamp or one of the many after market boards
> available? If it is a home brew pc board or after market
> board are pins 6 and 7 connected together on the connector?
> Dale Fleischmann
> > Hi,
> > but when i download the program thi message appare: "Hardware
> > connection failure! Check Serial cable and power supply."
> > thanks for all.
> > Riccardo Fanetti.
> > Do You Yahoo!?
> the Subject
> > and Body of the message will be ignored.
> Subject and Body of the message will be ignored.
