Trouble with connection a basic stamp to pc — Parallax Forums
edited 2002-04-17 13:37 in General Discussion
i want to connect a basic stamp II with my pc. I use
basic stamp 1.3 editor. The debug test work properly,
but when i download the program thi message appare:
"Hardware connection failure! Check Serial
cable and power supply."
I check the power supply and it's good, and also the
serial cable. The serial connection of my pc work
properly (i connect with a modem for a test)
does someone have the same problem ?
does someone have idea of how to fix ?
thanks for all.
Riccardo Fanetti.
__________________________________________________
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
http://taxes.yahoo.com/
    edited 2002-04-16 20:32
    Hi Riccardo Fanetti,
    Are you using an experimenter board or a home brew pc board on your project?
    Is it an experimenter board made for the Basic Stamp or one of the many after
    market boards available?
    If it is a home brew pc board or after market board are pins 6 and 7 connected
    together on the connector?
    Note, some after market boards do not connect pins 6 and 7 together.
    Hope this will help !!
    Dale Fleischmann
    Riccardo Fanetti wrote:
    > Hi,
    > thanks for all.
    > Riccardo Fanetti.
    > Do You Yahoo!?
    Do you have a DB25 to 9 pin adapater? These will often mess things up.
    Dale mentioned after market boards. All of ours have the correct
    connections, but I can't speak for any others.
    Al Williams
    AWC
    * Easy RS-232 Prototyping
    http://www.al-williams.com/awce/rs1.htm
    > From: Dale Fleischmann [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zP5t8plGBFsI4GD2tEbvNUSD59M03X2pcCY2t8fdzgdo3uXZLIz6q6oAysW0lcQmzXYYh2SoecT5zu0iDr5S]fleidale@c...[/url
    > Sent: Tuesday, April 16, 2002 2:33 PM
    > Subject: Re: [noparse][[/noparse]basicstamps] Trouble with connection a basic stamp to pc
    > board on your project? Is it an experimenter board made for
    > the Basic Stamp or one of the many after market boards
    > available? If it is a home brew pc board or after market
    > board are pins 6 and 7 connected together on the connector?
    > Dale Fleischmann
    > > Hi,
    > > but when i download the program thi message appare: "Hardware
    > > connection failure! Check Serial cable and power supply."
    > > thanks for all.
    > > Riccardo Fanetti.
    > > Do You Yahoo!?
    > the Subject
    > > and Body of the message will be ignored.
