74LS165 - Parallel in/serial out
Anyone using a '165 with the Stamp 2?? I can't seem to make it work. I have
the reverse function device (74HC595) working just fine but the 165 is giving
me a problem.
One possible thing is the clocking of the device. The '595 transfers the data
to the outputs when you pulse the "latch" pin. I don't see a similar pin on
this device.
Any help out there??
Mike B.
me a problem.
this device.
Mike B.
I have several 165's in series and they work great. Data from paralell
inputs is outputted to the stamp on pin 7. Use 1 for your enable low and
and 2 for clock. You will need 3 leads to your bs2. Pin 16 is 5V pin 9
goes to 10 to daisy chain 8 & 15 are grd. the rest are inputs. Use the
shiftin X,Y lsbpre [noparse][[/noparse]datain\16] for 2 devices.
Eric
Original Message
To: "Basicstamps@Yahoogroups.Com" <basicstamps@yahoogroups.com>
Sent: Sunday, April 14, 2002 7:13 PM
Subject: [noparse][[/noparse]basicstamps] 74LS165 - Parallel in/serial out
have the reverse function device (74HC595) working just fine but the 165 is
giving me a problem.
the data to the outputs when you pulse the "latch" pin. I don't see a
similar pin on this device.
> Mike B.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Thanks a lot!! I got screwed over by a clip lead that is OPEN !!!
Arrrgggg... It is work now but a bit strange. I will go make the changes
you suggest. Thanks, you saved me 2 stamp pins from the way I was trying to
make it work. I'm going to eventually be reading a two digit, BCD
thumbwheel switch..
Mike B.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Sunday, April 14, 2002 4:52 PM
Subject: Re: [noparse][[/noparse]basicstamps] 74LS165 - Parallel in/serial out
> Hi Mike:
> Eric
Original Message
> From: "Mike Blier" <w6ffc@p...>
is
> > Mike B.
and
Download the StampWorks documentation and code from the Parallax site for a
working example and documentation.
-- Jon Williams
-- Parallax
In a message dated 4/14/02 6:17:16 PM Central Daylight Time,
w6ffc@p... writes:
> is giving me a problem.
> data to the outputs when you pulse the "latch" pin. I don't see a similar
> pin on this device.
