Anemometer to PWM
Stampers,
With a few of you having built weather stations previously, I though I might
ask if anyone has code (or circuit ideas!) for the following application.
I need to take a reed switch closure from an anemometer(DAVIS brand) and
convert it's output to a 0-5 volt signal for an industrial application.
We only need to read "normal" wind speeds, eg nothing gale force!
I'm only asking as I don't want to reinvent the wheel!
Regards
Tim Stockman
Regards
Tim Stockman
My first try would be to feed the anemometer's output to COUNT, then
scale that result to serve as the argument for PWM to generate your
0-5 volts ouput. At first blush, seems it ought to work.
Steve
Tim Stockman, STOCKMAN ELECTR wrote:
> Stampers,
> though I might ask if anyone has code (or circuit ideas!) for
> brand) and convert it's output to a 0-5 volt signal for an
> industrial application. ...
>though I might ask if anyone has code (or circuit ideas!) for the
>Regards
>Tim Stockman
Hi Tim, I have such a circuit and code posted at
http://www.emesystems.com/OWL2face.htm#Annemometer
http://www.emesystems.com/images/WINX.gif
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
