Anemometer to PWM — Parallax Forums
Anemometer to PWM
edited 2002-04-10 06:39 in General Discussion
Stampers,
With a few of you having built weather stations previously, I though I might
ask if anyone has code (or circuit ideas!) for the following application.
I need to take a reed switch closure from an anemometer(DAVIS brand) and
convert it's output to a 0-5 volt signal for an industrial application.
We only need to read "normal" wind speeds, eg nothing gale force!
I'm only asking as I don't want to reinvent the wheel!
Regards
Tim Stockman
    edited 2002-04-10 06:20
    Stocky-
    My first try would be to feed the anemometer's output to COUNT, then
    scale that result to serve as the argument for PWM to generate your
    0-5 volts ouput. At first blush, seems it ought to work.
    Steve
    Tim Stockman, STOCKMAN ELECTR wrote:
    > Stampers,
    > though I might ask if anyone has code (or circuit ideas!) for
    > brand) and convert it's output to a 0-5 volt signal for an
    > industrial application. ...
    >Stampers,
    >though I might ask if anyone has code (or circuit ideas!) for the
    >Regards
    >Tim Stockman
    Hi Tim, I have such a circuit and code posted at
    http://www.emesystems.com/OWL2face.htm#Annemometer
    http://www.emesystems.com/images/WINX.gif
    -- regards,
    Tracy Allen
    mailto:tracy@e...
