controlling a servo motor
Does anyone know how I can control a servo motor to move
about 90 degrees clockwise and then return to its starting
position (within a time frame of about 8 seconds)? I'm working
with a basic stamp 2 and need to have a continous back and
forth motion but the only programming code I'm finding is for
continuous (modified) servo rotation. Any info is greatly
appreciated.
appreciated.
Quite simple actually.
The first thing you want to do is physically measure the rotation of the
servo by *carefully* turning it by hand. Some turn ~190-200 degrees or so,
others are slightly less that 180 degrees. If you want you can put a piece
of paper under the horn and mark the travel with reference to one of the
screw holes in the horn.
Secondly you need to figure out the PULSOUT period required to move the
servo to neutral / center / 90-degree position. The first thing you need is
the pulsewidth in milliseconds or microseconds that the servo requires to
move to the center position. Armed with this, divide the value for the
neutral position with the appropriate value from the table in the Stamp
manual in the PULSOUT section. This will give you the *approximate* value to
use in the PULSOUT statement. Make sure you use the same units.
For example, a Futaba 148 servo has a neutral position value of 1,520
microseconds. If I'm using a BS2, one period is 2 microseconds. So I divide
1520 by 2 and come up with 760. My PULSOUT statement would have a period of
760.
Here is sample code for moving the servo to the center position and holding
it there -- the servo is connected to PIN 0:
Loop:
PULSOUT 0,760
PAUSE 20
GOTO Loop
Before you run the code, turn the servo almost one way or the other -- this
is so you can see if it actually moves. If it does, you did good. You may
need to juggle the PERIOD value a bit to actually move the servo to the
center position. This is why you measure the rotation beforehand.
Now you can figure out the numbers for 0 degrees and 180 degrees (or as
close it you can get) and write the appropriate code to move and scan.
Original Message
> appreciated.
150 is centre
200 is one extreme
100 is the other
I maybe wrong
Ben
silver17audiocraft <averycording@h...> wrote: Does anyone know how I
appreciated.
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
BEN (TEAM DBR)
http://www.geocities.com/temdbr
Do You Yahoo!?
Get personalised at My Yahoo!.
.05 sec. to .50 sec. for 120 deg. of rotation. Because of this you'll need to
"step" the servo to increase the time of that movement to 8 sec.
One other option, though expensive, is to use a digital servo that is
programmable. The speed can be programmed using and external programmer. Not
sure if you can decrease the speed down that slow even with one of these.
Besides speed, you can also program the end points or total movement of the
servo and activate a "fail safe" position that the servo will return to if the
signal to it is lost.
While I'm sure someone could figure out what is needed to program these servos,
they are fairly new and I haven't seen that info. All of this doesn't come
cheap, the servo is about $90.00 and the programmer is about $250.00
Hank
> Ben
> appreciated.
of the message will be ignored.
> BEN (TEAM DBR)
> Do You Yahoo!?
