controlling a servo motor — Parallax Forums
edited 2002-04-02 17:22 in General Discussion
Does anyone know how I can control a servo motor to move
about 90 degrees clockwise and then return to its starting
position (within a time frame of about 8 seconds)? I'm working
with a basic stamp 2 and need to have a continous back and
forth motion but the only programming code I'm finding is for
continuous (modified) servo rotation. Any info is greatly
appreciated.
    edited 2002-04-02 02:40
    Charles E. Fromage says:
    Quite simple actually.
    The first thing you want to do is physically measure the rotation of the
    servo by *carefully* turning it by hand. Some turn ~190-200 degrees or so,
    others are slightly less that 180 degrees. If you want you can put a piece
    of paper under the horn and mark the travel with reference to one of the
    screw holes in the horn.
    Secondly you need to figure out the PULSOUT period required to move the
    servo to neutral / center / 90-degree position. The first thing you need is
    the pulsewidth in milliseconds or microseconds that the servo requires to
    move to the center position. Armed with this, divide the value for the
    neutral position with the appropriate value from the table in the Stamp
    manual in the PULSOUT section. This will give you the *approximate* value to
    use in the PULSOUT statement. Make sure you use the same units.
    For example, a Futaba 148 servo has a neutral position value of 1,520
    microseconds. If I'm using a BS2, one period is 2 microseconds. So I divide
    1520 by 2 and come up with 760. My PULSOUT statement would have a period of
    760.
    Here is sample code for moving the servo to the center position and holding
    it there -- the servo is connected to PIN 0:
    Loop:
    PULSOUT 0,760
    PAUSE 20
    GOTO Loop
    Before you run the code, turn the servo almost one way or the other -- this
    is so you can see if it actually moves. If it does, you did good. You may
    need to juggle the PERIOD value a bit to actually move the servo to the
    center position. This is why you measure the rotation beforehand.
    Now you can figure out the numbers for 0 degrees and 180 degrees (or as
    close it you can get) and write the appropriate code to move and scan.
    > appreciated.
    edited 2002-04-02 16:55
    Use the PULSOUT (pin number), (time in Millisecond)
    150 is centre
    200 is one extreme
    100 is the other
    I maybe wrong
    Ben
    silver17audiocraft <averycording@h...> wrote: Does anyone know how I
    appreciated.
    from the same email address that you subscribed. Text in the Subject and Body of
    the message will be ignored.
    BEN (TEAM DBR)
    http://www.geocities.com/temdbr
    Do You Yahoo!?
    Get personalised at My Yahoo!.
    I actual speed of the servo is set when it is designed and can be anywhere from
    .05 sec. to .50 sec. for 120 deg. of rotation. Because of this you'll need to
    "step" the servo to increase the time of that movement to 8 sec.
    One other option, though expensive, is to use a digital servo that is
    programmable. The speed can be programmed using and external programmer. Not
    sure if you can decrease the speed down that slow even with one of these.
    Besides speed, you can also program the end points or total movement of the
    servo and activate a "fail safe" position that the servo will return to if the
    signal to it is lost.
    While I'm sure someone could figure out what is needed to program these servos,
    they are fairly new and I haven't seen that info. All of this doesn't come
    cheap, the servo is about $90.00 and the programmer is about $250.00
    Hank
    > Ben
    > appreciated.
    > BEN (TEAM DBR)
    > Do You Yahoo!?
