Javelin Stamp as interpretator or Javelin
So are we talking about a Java front end on the PC generating
virtually the same set of tokens for interpretation by the Stamp?
IOW, is the Stamp interpreter "core" pretty much unchanged (16-bit
workspace, integer math, no interrupts...) aside from the VPs?
No criticism/offense intended--only trying to get a feel for this
new critter. The Javelin sounds like a great tool to learn/teach
Java; I'm just trying to decide if it's worth learning Java in order
to use a Javelin.
Steve
On 19 Mar 02 at 17:42, selmaware wrote:
> The Javelin IDE compiles the program into compressed byte codes. An
> on-stamp interpreter then uses the byte-code program to run. -Martin
> Hebel
to use a Javelin.
Steve
> Hebel
Thanks for the reply. Maybe I'm just having a prolonged senior
moment or I'm jumping the documentation gun, but I'm in a very thick
fog here. I've yet to see real specifics about what the Javelin
Stamp offers over a BASIC Stamp in terms of the language itself.
This is not a criticism--it's meant as feedback to Parallax.
Because it's a Parallax product, I'd expect it to be "cool" but that
tells me little about its functionality. What new tricks can a
Javelin Stamp do? For us non-Java-heads, why would the effort be
worth it--what could we do (again, functionality) with a Javelin
Stamp that we couldn't with a BASIC Stamp? Likewise, "subset of
Java" raises more questions for me than it answers. Some specifics
of the Javelin's language would help. For instance:
- variables types allowed (integer, float, long, arrays...?)
- control structures (if-then-else, case, do-while...?)
- native math support (trig, log, sqr, exponentiation...?)
- interrupt processing capabilities?
Please, I'm begging you, convince me that I need at least one!
Thanks and regards,
Steve
Cheaper, floating point math, and upto 1MB SRAM for 67$.
Robert Staph, W3RCS
The Center for Advanced Technologies
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, March 18, 2002 10:20 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Javelin Stamp as interpretator or Javelin
> to use a Javelin.
> Regards,
> Steve
> > Hebel
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
The Javelin is not a Stamp and as far as I know does not use the same
tokenized codes (I didn't say it doesn't use tokenized codes; I said not
the same ones). The compiler is all new and it isn't just a new piece of
software on the PC side. For example, code is stored in EEPROM but runs
from RAM (fast).
I've used the TINI. It is great -- like a little bitty PC on a SIMM.
However, as I pointed out in my article in embedded about the TINI and
the Javelin (someone recently posted that link) they really are apples
an oranges.
The TINI is like a little PC and so has all the problems PCs have.
Unpredictable garbage collection; hard to quantify execution times; etc.
The Javelin is very much like a Stamp in that it is predictable and has
specialized commands to do the things you often do in embedded systems.
The language is Java-like, but not Java for this reason.
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
Original Message
> From: Robert Staph [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TUqIy_Rtmxv-vD42D3RQMVOGWpUaYEI8igyCMIFRBVytI6ME900fLG7LrD9oQ40BqU798EeWxsKRzg]rstaph@a...[/url
> Sent: Tuesday, March 19, 2002 1:35 PM
> To: basicstamps@yahoogroups.com
> or Javelin
> You might be better off with a Dallas Semiconductor TINI to
> learn Java on... Cheaper, floating point math, and upto 1MB
> SRAM for 67$.
> Robert Staph, W3RCS
Original Message
> From: "S Parkis" <parkiss@e...>
> or Javelin
> Stamp? IOW,
> for this new
> > critter. The Javelin sounds like a great tool to learn/teach Java;
> order to use
> > a Javelin.
> > Regards,
> > Steve
> codes. An
> run. -Martin
> > > Hebel
> the Subject
> > and
> Subject and Body of the message will be ignored.
Java compiler (we use Jikes, from IBM) and are not Stamp-compatible (that is,
Javelin tokens will not run on a BASIC Stamp). In fact, the Javelin team had
to work pretty hard to create a lot of Stamp compatibility in the Javelin
library.
In the end, it's a cool new product and Java-heads around the world wanting
to get into embedded control will be happy. For the rest of us who have
already had fun with the BASIC Stamp, I feel that learning Java is worth it
and it gives us another tool to solve problems with.
The Javelin won't replace the BASIC Stamp, it's just a cool new beast in the
line. More choices for more programmers -- especially those who turn their
nose up at BASIC.
-- Jon Williams
-- Parallax
In a message dated 3/19/02 1:32:25 PM Central Standard Time,
parkiss@e... writes:
> to use a Javelin.
What? The PC's garbage collection / execution times issue have solely to
do with the software that runs on them (notably the operating system), not
anything inherent with the PC. If you run an actual RTOS on top of a PC,
with a preemptable kernel, etc, you'll find extremely predictable run
times. At its core, they're not so different, the PC system is just faster
and has a more complex architecture.
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
on a typical OS.
Al Williams
AWC
Original Message
> From: Sean T. Lamont .lost. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TLzRBUWe1Zd21Il7Jn6c0kv_EHQTBno-nX-YUOSrDDIORFvsQIkSCplc1oDUFAF9RRbLzw8qvsq0OAXh3w]lamont@a...[/url
> Sent: Tuesday, March 19, 2002 6:12 PM
> Subject: RE: [noparse][[/noparse]basicstamps] Re: Javelin Stamp as interpretator
> or Javelin
> > etc. The Javelin is very much like a Stamp in that it is
> predictable
> > and has specialized commands to do the things you often do
> in embedded
> > systems. The language is Java-like, but not Java for this reason.
> have solely to do with the software that runs on them
> (notably the operating system), not anything inherent with
> the PC. If you run an actual RTOS on top of a PC, with a
> run times. At its core, they're not so different, the PC
> system is just faster and has a more complex architecture.
> (ServNet)
> Tacoma - Bremerton
week or longer waiting period to get one at this time. Although it is a nice
product, it
looks like you'd need more than just the SIMM stick board to get it working.
You have
to fill out their software license agreement, and you'd still need software
to program it with, that looked to be extra but there wasn't info on it.
Plus you'd probably need their dev board in order to get started.
https://store.ibutton.com/cgi-bin/ncommerce3/CategoryDisplay?cgrfnbr=804&cgm
enbr=776&cg=804
The Javalin is a lot easier to deal with in that respect, and we don't have
a 12 week plus waiting period. Albeit, the 512kb or 1mb models are mighty
tempting. All you have to do is plug the javelin into a Stamp proto board of
some type, hook up the serial port and your in business. 32kb is nice to
deal with when your starting. Plus they have support a manual etc., with the
TINI your on your own.
Original Message
From: Robert Staph [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1FkkDdZYdhhEB53bAkp--u0BJbYMaH7w1Miiudj63-J9KEynaxVpcUVrXrhC6B-ET3arBnecwfVM4sib]rstaph@a...[/url
You might be better off with a Dallas Semiconductor TINI to learn Java on...
Robert Staph, W3RCS
Original Message
> to use a Javelin.
> Regards,
> Steve
> > Hebel
with than just moving on to something better. Parallax does have a wickedly
advanced manual compared to EVERY other micro I've found. Couple that with
the great learning activities created by Parallax and others and its the
best bet for entry into the world of micros. But all that doesn't make up
for the lack of floating point math for me.
Now the multi-tasking of the Javelin may get parallax one more purchase from
me, but after that only floating point math will get me to take another
look.
As far as the wait, that can't be helped, you'll be waiting a couple of
weeks for the Javelin I think too. Especially if Parallax didn't make
enough for the rush I suspect there will be on them. But there are other
package solutions dealing with the TINI from third parties. You may want to
check to see if UVI has any of their stuff in stock
http://www.vinculum.com/products.php From what I've seen some prices on the
the Javelin Stamp Starter Kit (#27237 - $239) you could put together a nice
TINI setup.
Software is just a little extra config from the standard free JDK from Sun.
-Rob
Original Message
Sent: Tuesday, March 19, 2002 9:37 PM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Javelin Stamp as interpretator or Javelin
> I took a look at the Tini and although it is most interesting, there is a
12
nice
> product, it
working.
> You have
software
> enbr=776&cg=804
have
of
the
Original Message
> From: Robert Staph [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8efCMJMSIj3xBzDahVkVdt54zGiaTegFtbWqqxG-WrL918Srw9SZbSU4YpKsjDi-37vnV5TFM5e7F60]rstaph@a...[/url
on...
> Robert Staph, W3RCS
Original Message
> > to use a Javelin.
> > Regards,
> > Steve
> > > Hebel
and
those interested to the web site: www.javelinstamp.com.
Here's what excites me:
-- flat 32K program space
-- structured programming
-- reusable, object-oriented code
-- up to six virtual peripherals (background tasks)
The VPs will probably get the most attention from Stamp users. Receiving
serial data on-the-fly is now available by installing a receive UART VP.
Other VPs are ADC, DAC, PWM (motor control -- not D2A like BASIC Stamp) and a
timer.
Yes, the language is a subset of Java -- having mostly to do with it being an
embedded micro versus running on a PC. So those libraries that are important
to the PC world (i.e., graphics) are not appropriate and not included. The
Javelin Stamp comes with custom classes that aren't found in the PC world --
again, having to do with embedded control.
The are, of course, other differences between Java and the Javelin and they
are detailed in the manual that can be downloaded from the Javelin web site.
-- Jon Williams
-- Parallax
In a message dated 3/19/02 11:48:18 PM Central Standard Time,
> Jon-
> Thanks and regards,
> Steve
For a BASIC Stamp user the benefits are in four areas:
* Background I/O
This is a ability to run multiple buffered UARTs, or PWM, or ADC in the
background while doing other processing. I think that for any BASIC Stamp
user the benefits are obvious.
* More memory
You will find that 32kB is a lot more memory in practice than it sounds like
on paper. I have written a large number of very complex applications with
the Javelin and running out of memory has never been an issue. Having more
memory means that you can write simpler code and not have to think so hard
about carefully allocating registers.
* Structured programming language
IMHO this is the largest benefit of all, although it is perhaps the least
obvious benefit too. Being a structured language, Java encourages
programmers to divide their programs up into suboutines (called methods in
Java) and classes. Although there is more to learn so that you can take
advantage of methods and classes, the payback is immense in terms of more
readable code, fewer bugs, and greater reusability. If you have ever read
anything about Java you will probably have have come across this term
'reusability' before. Java allows programmers to group functionality
together into a class (for non object-oriented programmers, you can consider
a class to simply be a file with contains related code), an example of a
class might be a collection of methods for accessing a DS1620 digital
thermometer. By collecting all of the I/O routines necessary for the DS1620
into a single class and providing a simple set of methods (like
'getCelsiusTemp()') you can hide the complexity of a subset of your program
behind an easy to use interface. The real power comes when you can reuse
code developed by other people, and the Java file structure makes this easy.
For example, the floating point support that several people have asked for
can be released as an add-on class which is easily integrated into an
existing project.
* Interactive debugging
Interative, step, run, stop and variable inspection makes it easier and
faster to identify and fix problems.
All of these benefits together mean that you can build larger systems more
quickly, and more reliably.
Chris.
Original Message
> From: S Parkis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=d_LeVRYI6R9rxRCTLN7lvoszw-laNCoxyll_egJc3roDmfOAnr7fQfSCS-HFbxMwMlwfXiYPVZ-zssRy]parkiss@e...[/url
> Sent: Tuesday, March 19, 2002 5:35 AM
> or Javelin
> Jon-
> Thanks and regards,
> Steve
However, to be totally comparable you need some really sucky documentation
and too-small holes drilled in your expansion boards. <grin>
Original Message
> Since I am not yet a "Java-head" I should leave it to the experts and
point
and a
> timer.
looking horrible, much because of language limitations. Even commodore
basic could do a statement like "if x=0 then y=y+1", something that you
can't do on a BS2 without an ugly label/branch. The VP stuff is cool, but
I'm not sure if it might actually be cheaper to buy a real uart?
On Wed, 20 Mar 2002, Rodent wrote:
> Sounds alot like what an OOPic has as far as the virtual peripherals.
Original Message
> point
> and a
> > timer.
> from the same email address that you subscribed. Text in the Subject and Body
There is a floating point class written for the Javelin. It still needs
some refinement and might not make it into the install package. Not to
worry though, if it does not appear in the install package, it will be
available soon from www.javelinstamp.com.
Regards, Andy
Original Message
From: Robert Staph [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=y_PdrGCV2pDF4g_q23bcst6hv9Dmx0XfAvaJWCKFiYpHnMi1lRIJbWaTOabMl1Y9caHF93Jd5RmgejZj]rstaph@a...[/url
Sent: Tuesday, March 19, 2002 8:33 PM
Just a suggestion, I've found the limitations of the stamp harder to deal
look.
TINI setup.
-Rob
Original Message
12
nice
> product, it
working.
> You have
software
> enbr=776&cg=804
have
of
the
Original Message
on...
> Robert Staph, W3RCS
Original Message
> > to use a Javelin.
> > Regards,
> > Steve
> > > Hebel
and
