BS1 Hiccup
I'm using a BS1 to latch and unlatch a door. The stamp is connected
to two relays using 10K resistors and 2N2222 transistors (through pin4
to latch and pin5 to unlatch). The relays are 12V, capable of 5A and
are used to switch power to an electric motor (3A max) that latches
and unlatches a door. Two more pins are used to turn off the motor
once enough travel has occured (pin3 when latched and pin2 when
unlatched). The respective pins are made high (+5 from an external
source) when a microswitch closes. Finally pin7 is connected to a
microswitch that calls for latch when high and unlatch when low. The
relays are powered from a car battery, and the stamp is powered from a
+5 volt power supply, with all grounds together.
The program runs fine, except it randomly starts over! The stamp
seems to hiccup when the relays open or sometimes when the relays
close. But it doesn't happen all the time. Everything might work
perfectly for 5 or 6 latches and unlatches and then the hiccup might
occur 3 or 4 times in a row where the stamp just seems to reset itself
and start over at the top (the pause 2000 is inserted so I can tell
when this occurs). It might even do this a few times in a row before
normal program execution continues.
What could be causing this?
pause 2000
loop:
low 4
low 5
if pin7=1 then latch
if pin7=0 then unlatch
goto loop
latch:
if pin3=1 then loop
high 4
goto latch
unlatch:
if pin2=1 then loop
high 5
goto unlatch
pause 2000
loop:
low 4
low 5
goto loop
latch:
if pin3=1 then loop
high 4
goto latch
unlatch:
if pin2=1 then loop
high 5
goto unlatch
things to do.
1) If possible, isolate the relay power from the Stamp power. Have a
common ground in any event and make that ground as solid as possible
(not very thin wire).
2) Put a large capacitor on the Stamp's 5V bus. This will slow its start
up, but will also give it some extra time when the power browns out.
Try, say, 1000uF between 5V and ground as close to the Stamp as is
practical.
3) If noise coupling might be a problem, considering holding the reset
line to 5V through a low value pull up (4.7K) instead of relying on the
Stamp to do it.
There is an article about this in the Stamp FAQ at
http://www.al-williams.com/wd5gnr/stampfaq.htm if you want to read more
about it.
Good luck!
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
Original Message
> From: bdespins [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rqXnEiDhjGUyJSX7BbCs1Th3M1sIXhMYzNOoZI3fHm5HgBkKcoKpCKE7-F3TVjPGGi-qCkZyCOIfgp5QspE]bdespins@t...[/url
> Sent: Sunday, March 10, 2002 8:02 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] BS1 Hiccup
> (through pin4
> powered from a
> reset itself
> pause 2000
> loop:
> low 4
> low 5
> goto loop
> latch:
> if pin3=1 then loop
> high 4
> goto latch
> unlatch:
> if pin2=1 then loop
> high 5
> goto unlatch
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Hi ??? -
Just a few thoughts -
Which pin are you using to power the Stamp, Pin 1 or Pin 5 ?
If Pin 1 is being used the MINIMUM ACCEPTABLE voltage is 5.5 VDC.
Is there any possibility the motor is drawing excess current at
end-of-travel ? Ergo it's not being shut down soon enough. If so, this
might cause a dip in the supplied power, causing the Stamp to reset.
Which power source is being used for Pin 7 ?
Regardless of how you have the circuit described, have you ever seen
BOTH relays engaged at the same time ?
Bruce Bates
filtering for the power going to the BS1 -- maybe a 0.1 mfd and 220 mfd
capacitor across the power input of the Stamp. If you are using an external
voltage regulator to power the Stamp, consider using some filtering as
specified by the regulator documentation.
Try running the Stamp off a 9v battery and see what happens.
Original Message
if all fails try some opto isolators on the inputs.
regards
victor
Original Message
To: basicstamps@yahoogroups.com <basicstamps@yahoogroups.com>
Date: Sunday, March 10, 2002 9:09 AM
Subject: RE: [noparse][[/noparse]basicstamps] BS1 Hiccup
>This isn't that unusual. The relay coils are causing a reset. A few
>things to do.
>practical.
>Stamp to do it.
>about it.
>Good luck!
>Al Williams
>AWC
Original Message
>> From: bdespins [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=M09bhrsJPWeLlcgF3qRPMzLimKAJNMGG_PVyOmxS-f6sw9qcrhfpJsKnnl_uQx_TiVFXzhJfJs2tnwq4S0ZRcg]bdespins@t...[/url
>> (through pin4
>> powered from a
>> reset itself
>> pause 2000
>> loop:
>> low 4
>> low 5
>> goto loop
>> latch:
>> if pin3=1 then loop
>> high 4
>> goto latch
>> unlatch:
>> if pin2=1 then loop
>> high 5
>> goto unlatch
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Unfortunately none of the suggestions improved the Stamp randomly
resetting. I've decided to go with an H-bridge to control the motor
instead of relays.
Thanks again.
Bernard Despins
across each relay coil to kill any back emf? Back emf will cause a random
reset. I know, because I've seen it happen every time there's been a relay
with no doide across the coil.
A 1N4007 will do the trick (Anode towards V+, Cathode towards ground side of
the coil).
Cheers,
Ben.
http://www.lennard.net.nz/
Ben Lennard, NCEE, Dip EE
Web Hosting and Electronics R&D
Club Coordinator, Victoria University of Wellington Hockey Club
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
Subject: [noparse][[/noparse]basicstamps] Re: BS1 Hiccup
Date: Tue, 12 Mar 2002 6:22 PM
Thanks to all who suggested fixes for my hiccuping stamp.
instead of relays.
Thanks again.
Bernard Despins
twd.
the V+.
Russ
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Tuesday, March 12, 2002 12:39 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: BS1 Hiccup
| I must have missed this one, but did anyone check that you have a diode
| the coil).
| Cheers,
| Ben.
| Hm: +64 4 972 7567
| Mb: +64 21 536 627
| 87 Spencer Street
| Crofton Downs
| Wellington
| New Zealand
| instead of relays.
| Thanks again.
| Bernard Despins
| from the same email address that you subscribed. Text in the Subject and Body
diode
random
a relay
Yes I have diodes across the relays. I've tried everything from
de-bouncing my inputs (first thing I tried until I realized the stamp
was actually resetting). Tried holding the reset pin high, tried
putting a large capacitor on the stamp's power supply, tried powering
the stamp with a 9V battery instead of the 12V car battery powering
the relays or the +5V regulator that is powering the microswitches.
Tried using a different stamp. I spent two days trying anything and
everything. I finally gave up and I'm going for an H-bridge. I
considered optoisolators, but since that involves a redesign anyway,
I'm going to get rid of the relays and I'm going to step up to a BS2
industrial version so that the setup will operate over a wider range
of temperatures.
Bernard Despins
Hehe, you're right, and that's always the way to do it, as in my circuits.
I just got the names wrong. For those who, like me, can get the names
wrong, let's try it this way:
The end of the diode with the band around it goes towards +V (that is the
Cathode - NOT Anode, as I accidentally said before).
Cheers, and well spotted Russ!
Ben, in Windy Wellington, New Zealand.
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
Date: Wed, 13 Mar 2002 1:14 AM
Sorry for butting in, but I think you should orient the diode with the
cathode twd.
the V+.
Russ
Original Message
relay
of
| the coil).
| Cheers,
| Ben.
| Hm: +64 4 972 7567
| Mb: +64 21 536 627
| 87 Spencer Street
| Crofton Downs
| Wellington
| New Zealand
be."
| instead of relays.
| Thanks again.
| Bernard Despins
The way my memory is these days, I was lucky to
remember what a diode was.
regards
Russ
Original Message
Sent: Wednesday, March 13, 2002 4:40 AM
| Oops!
| Hm: +64 4 972 7567
| Mb: +64 21 536 627
| 87 Spencer Street
| Crofton Downs
| Wellington
| New Zealand
| cathode twd.
| the V+.
| Russ
Original Message
| relay
| of
| | the coil).
| | Cheers,
| | Ben.
| | Hm: +64 4 972 7567
| | Mb: +64 21 536 627
| | 87 Spencer Street
| | Crofton Downs
| | Wellington
| | New Zealand
| be."
| | instead of relays.
| | Thanks again.
| | Bernard Despins
