BS1 Hiccup — Parallax Forums
BS1 Hiccup
edited 2002-03-13 12:32 in General Discussion
I'm using a BS1 to latch and unlatch a door. The stamp is connected
to two relays using 10K resistors and 2N2222 transistors (through pin4
to latch and pin5 to unlatch). The relays are 12V, capable of 5A and
are used to switch power to an electric motor (3A max) that latches
and unlatches a door. Two more pins are used to turn off the motor
once enough travel has occured (pin3 when latched and pin2 when
unlatched). The respective pins are made high (+5 from an external
source) when a microswitch closes. Finally pin7 is connected to a
microswitch that calls for latch when high and unlatch when low. The
relays are powered from a car battery, and the stamp is powered from a
+5 volt power supply, with all grounds together.
The program runs fine, except it randomly starts over! The stamp
seems to hiccup when the relays open or sometimes when the relays
close. But it doesn't happen all the time. Everything might work
perfectly for 5 or 6 latches and unlatches and then the hiccup might
occur 3 or 4 times in a row where the stamp just seems to reset itself
and start over at the top (the pause 2000 is inserted so I can tell
when this occurs). It might even do this a few times in a row before
normal program execution continues.
What could be causing this?
pause 2000
loop:
low 4
low 5
if pin7=1 then latch
if pin7=0 then unlatch
goto loop
latch:
if pin3=1 then loop
high 4
goto latch
unlatch:
if pin2=1 then loop
high 5
goto unlatch
    edited 2002-03-10 14:08
    This isn't that unusual. The relay coils are causing a reset. A few
    things to do.
    1) If possible, isolate the relay power from the Stamp power. Have a
    common ground in any event and make that ground as solid as possible
    (not very thin wire).
    2) Put a large capacitor on the Stamp's 5V bus. This will slow its start
    up, but will also give it some extra time when the power browns out.
    Try, say, 1000uF between 5V and ground as close to the Stamp as is
    practical.
    3) If noise coupling might be a problem, considering holding the reset
    line to 5V through a low value pull up (4.7K) instead of relying on the
    Stamp to do it.
    There is an article about this in the Stamp FAQ at
    http://www.al-williams.com/wd5gnr/stampfaq.htm if you want to read more
    about it.
    Good luck!
    Al Williams
    AWC
    * Floating point A/D
    http://www.al-williams.com/awce/pak9.htm
    > From: bdespins [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rqXnEiDhjGUyJSX7BbCs1Th3M1sIXhMYzNOoZI3fHm5HgBkKcoKpCKE7-F3TVjPGGi-qCkZyCOIfgp5QspE]bdespins@t...[/url
    > Sent: Sunday, March 10, 2002 8:02 AM
    > Subject: [noparse][[/noparse]basicstamps] BS1 Hiccup
    > (through pin4
    > powered from a
    > reset itself
    > pause 2000
    > loop:
    > low 4
    > low 5
    > goto loop
    > latch:
    > if pin3=1 then loop
    > high 4
    > goto latch
    > unlatch:
    > if pin2=1 then loop
    > high 5
    > goto unlatch
    > from the same email address that you subscribed. Text in the
    edited 2002-03-10 14:35
    Hi ??? -
    Just a few thoughts -
    Which pin are you using to power the Stamp, Pin 1 or Pin 5 ?
    If Pin 1 is being used the MINIMUM ACCEPTABLE voltage is 5.5 VDC.
    Is there any possibility the motor is drawing excess current at
    end-of-travel ? Ergo it's not being shut down soon enough. If so, this
    might cause a dip in the supplied power, causing the Stamp to reset.
    Which power source is being used for Pin 7 ?
    Regardless of how you have the circuit described, have you ever seen
    BOTH relays engaged at the same time ?
    Bruce Bates
    edited 2002-03-10 15:00
    You need to check the state of your batteries and possibly provide some
    filtering for the power going to the BS1 -- maybe a 0.1 mfd and 220 mfd
    capacitor across the power input of the Stamp. If you are using an external
    voltage regulator to power the Stamp, consider using some filtering as
    specified by the regulator documentation.
    Try running the Stamp off a 9v battery and see what happens.
    edited 2002-03-10 19:53
    also try some software debounce on your inputs.
    if all fails try some opto isolators on the inputs.
    regards
    victor
    To: basicstamps@yahoogroups.com <basicstamps@yahoogroups.com>
    Date: Sunday, March 10, 2002 9:09 AM
    Subject: RE: [noparse][[/noparse]basicstamps] BS1 Hiccup
    >things to do.
    >practical.
    >Stamp to do it.
    >about it.
    >Good luck!
    >Al Williams
    >AWC
    >> From: bdespins [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=M09bhrsJPWeLlcgF3qRPMzLimKAJNMGG_PVyOmxS-f6sw9qcrhfpJsKnnl_uQx_TiVFXzhJfJs2tnwq4S0ZRcg]bdespins@t...[/url
    >> (through pin4
    >> powered from a
    >> reset itself
    >> pause 2000
    >> loop:
    >> low 4
    >> low 5
    >> goto loop
    >> latch:
    >> if pin3=1 then loop
    >> high 4
    >> goto latch
    >> unlatch:
    >> if pin2=1 then loop
    >> high 5
    >> goto unlatch
    >from the same email address that you subscribed. Text in the Subject and
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2002-03-12 05:22
    Thanks to all who suggested fixes for my hiccuping stamp.
    Unfortunately none of the suggestions improved the Stamp randomly
    resetting. I've decided to go with an H-bridge to control the motor
    instead of relays.
    Thanks again.
    Bernard Despins
    edited 2002-03-12 05:39
    I must have missed this one, but did anyone check that you have a diode
    across each relay coil to kill any back emf? Back emf will cause a random
    reset. I know, because I've seen it happen every time there's been a relay
    with no doide across the coil.
    A 1N4007 will do the trick (Anode towards V+, Cathode towards ground side of
    the coil).
    Cheers,
    Ben.
    http://www.lennard.net.nz/
    Ben Lennard, NCEE, Dip EE
    Web Hosting and Electronics R&D
    Club Coordinator, Victoria University of Wellington Hockey Club
    Hm: +64 4 972 7567
    Mb: +64 21 536 627
    87 Spencer Street
    Crofton Downs
    Wellington
    New Zealand
    "To the optimist, the glass is half full. To the pessimist, the glass is
    half empty. To the engineer, the glass is twice as big as it needs to be."
    No animals were harmed in the transmission of this email, although the
    Dog next door is living on borrowed time, let me tell you! Those of you
    with an overwhelming fear of the unknown will be gratified to learn that
    there is no hidden message revealed by reading this warning backwards.
    Subject: [noparse][[/noparse]basicstamps] Re: BS1 Hiccup
    Date: Tue, 12 Mar 2002 6:22 PM
    instead of relays.
    Thanks again.
    Bernard Despins
    edited 2002-03-12 12:14
    Sorry for butting in, but I think you should orient the diode with the cathode
    twd.
    the V+.
    Russ
    Sent: Tuesday, March 12, 2002 12:39 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: BS1 Hiccup
    | the coil).
    | Cheers,
    | Ben.
    | Hm: +64 4 972 7567
    | Mb: +64 21 536 627
    | 87 Spencer Street
    | Crofton Downs
    | Wellington
    | New Zealand
    | instead of relays.
    | Thanks again.
    | Bernard Despins
    | from the same email address that you subscribed. Text in the Subject and Body
    edited 2002-03-13 05:32
    diode
    random
    a relay
    Yes I have diodes across the relays. I've tried everything from
    de-bouncing my inputs (first thing I tried until I realized the stamp
    was actually resetting). Tried holding the reset pin high, tried
    putting a large capacitor on the stamp's power supply, tried powering
    the stamp with a 9V battery instead of the 12V car battery powering
    the relays or the +5V regulator that is powering the microswitches.
    Tried using a different stamp. I spent two days trying anything and
    everything. I finally gave up and I'm going for an H-bridge. I
    considered optoisolators, but since that involves a redesign anyway,
    I'm going to get rid of the relays and I'm going to step up to a BS2
    industrial version so that the setup will operate over a wider range
    of temperatures.
    Bernard Despins
    edited 2002-03-13 09:40
    Oops!
    Hehe, you're right, and that's always the way to do it, as in my circuits.
    I just got the names wrong. For those who, like me, can get the names
    wrong, let's try it this way:
    The end of the diode with the band around it goes towards +V (that is the
    Cathode - NOT Anode, as I accidentally said before).
    Cheers, and well spotted Russ!
    Ben, in Windy Wellington, New Zealand.
    Hm: +64 4 972 7567
    Mb: +64 21 536 627
    87 Spencer Street
    Crofton Downs
    Wellington
    New Zealand
    Date: Wed, 13 Mar 2002 1:14 AM
    cathode twd.
    the V+.
    Russ
    relay
    of
    | the coil).
    | Cheers,
    | Ben.
    | Hm: +64 4 972 7567
    | Mb: +64 21 536 627
    | 87 Spencer Street
    | Crofton Downs
    | Wellington
    | New Zealand
    be."
    | instead of relays.
    | Thanks again.
    | Bernard Despins
    Glad to have helped.
    The way my memory is these days, I was lucky to
    remember what a diode was.
    regards
    Russ
    Sent: Wednesday, March 13, 2002 4:40 AM
    | Oops!
    | Hm: +64 4 972 7567
    | Mb: +64 21 536 627
    | 87 Spencer Street
    | Crofton Downs
    | Wellington
    | New Zealand
    | cathode twd.
    | the V+.
    | Russ
    | relay
    | of
    | | the coil).
    | | Cheers,
    | | Ben.
    | | Hm: +64 4 972 7567
    | | Mb: +64 21 536 627
    | | 87 Spencer Street
    | | Crofton Downs
    | | Wellington
    | | New Zealand
    | be."
    | | instead of relays.
    | | Thanks again.
    | | Bernard Despins
