SED1330 Graphic LCD
hello,
I've been looking for a large graphic lcd display that can easily be controlled
by a stamp. I've enjoyed using Seetron's 128x64 serial display but need
something larger. The SED1330 controller seems to be very common in larger
256x128 and 320x240 displays, has anyone interfaced this controller with a
stamp? I've also seen a serial LCD controller that works with the SED1330, has
anyone here used this before?
http://www.angelfire.com/electronic/micropakindustries/page3.html
Any advice would be apprecitated, Thanks!
Stewart
Stewart
> larger 256x128 and 320x240 displays, has anyone
> interfaced this controller with a stamp?
I did a quick Google search, and came across this:
http://www.compsys1.com/workbench/Benchware/SED1330/sed1330.html
The main code can be found at:
ftp://207.73.33.32/pub/PBP_Files/sed1330/glsedemo.bas
It's written in a language similar to PBASIC, but not identical. This along
with a datasheet or two would probably be enough to let you get it doing
basic stuff, but you'd have to have a look yourself.
Good luck,
Michael
I used that controller, very easy to use, you only need to send serout
commands to the controller, i used it to interface a 320x200 SED1330
LCD display to do a temperature histogram, please check some pics on my
webpage:
http://electronics.tocache.org
Thursday, March 07, 2002, 11:00:02 AM, you wrote:
SM> hello,
SM> I've been looking for a large graphic lcd display that can easily be
controlled by a stamp. I've enjoyed using Seetron's 128x64 serial display but
need something larger. The SED1330 controller
SM> seems to be very common in larger 256x128 and 320x240 displays, has anyone
interfaced this controller with a stamp? I've also seen a serial LCD controller
that works with the SED1330, has anyone
SM> here used this before?
SM> http://www.angelfire.com/electronic/micropakindustries/page3.html
SM> Any advice would be apprecitated, Thanks!
SM> Stewart
Best regards,
Kalun mailto:klnlau@v...
you double check it and send it again?
Stewart
On Thu, 7 Mar 2002 12:50:40 -0500, Kalun Lau wrote:
>Hello Stewart,
>webpage:
