SED1330 Graphic LCD — Parallax Forums
SED1330 Graphic LCD
edited 2002-03-08 15:28 in General Discussion
hello,
I've been looking for a large graphic lcd display that can easily be controlled
by a stamp. I've enjoyed using Seetron's 128x64 serial display but need
something larger. The SED1330 controller seems to be very common in larger
256x128 and 320x240 displays, has anyone interfaced this controller with a
stamp? I've also seen a serial LCD controller that works with the SED1330, has
anyone here used this before?
http://www.angelfire.com/electronic/micropakindustries/page3.html
Any advice would be apprecitated, Thanks!
Stewart
    edited 2002-03-07 17:10
    Hey,
    > larger 256x128 and 320x240 displays, has anyone
    > interfaced this controller with a stamp?
    I did a quick Google search, and came across this:
    http://www.compsys1.com/workbench/Benchware/SED1330/sed1330.html
    The main code can be found at:
    ftp://207.73.33.32/pub/PBP_Files/sed1330/glsedemo.bas
    It's written in a language similar to PBASIC, but not identical. This along
    with a datasheet or two would probably be enough to let you get it doing
    basic stuff, but you'd have to have a look yourself.
    Good luck,
    Michael
    edited 2002-03-07 17:50
    Hello Stewart,
    I used that controller, very easy to use, you only need to send serout
    commands to the controller, i used it to interface a 320x200 SED1330
    LCD display to do a temperature histogram, please check some pics on my
    webpage:
    http://electronics.tocache.org
    Thursday, March 07, 2002, 11:00:02 AM, you wrote:
    SM> hello,
    SM> I've been looking for a large graphic lcd display that can easily be
    controlled by a stamp. I've enjoyed using Seetron's 128x64 serial display but
    need something larger. The SED1330 controller
    SM> seems to be very common in larger 256x128 and 320x240 displays, has anyone
    interfaced this controller with a stamp? I've also seen a serial LCD controller
    that works with the SED1330, has anyone
    SM> here used this before?
    SM> http://www.angelfire.com/electronic/micropakindustries/page3.html
    SM> Any advice would be apprecitated, Thanks!
    SM> Stewart
    Best regards,
    Kalun mailto:klnlau@v...
    I'd like to check out your project, but am having trouble with the link. Could
    you double check it and send it again?
    Stewart
    On Thu, 7 Mar 2002 12:50:40 -0500, Kalun Lau wrote:
    >Hello Stewart,
    >webpage:
