serin freezes
I am using a couple of TWS-434 and RWS-434's from www.rentron.com to
implement radio communication between two BSII's. I am having trouble with
the serin command. I am using the time out feature of the command, and it
works fine for a dozen or so passes and then it hangs. The actual code is:
SERIN RFIn, Baud3, 100, TryAgain, [noparse][[/noparse]wait{"Base"),TPacketCount, TPacketData]
When there is no incoming data, the program control will loop through the
TryAgain jump roughly 6 to 25 times and then it will just freeze on the
above line of code. Any thoughts?
Rafe
Rafe
http://www.rentron.com/Stamp_RF.htm
I hope that helps.
> www.rentron.com to
> just freeze on the
> Rafe
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
__________________________________________________
Do You Yahoo!?
Try FREE Yahoo! Mail - the world's greatest free email!
http://mail.yahoo.com/
the time out feature or SERIN. I'll play with the hardware and see if it
happens with different hardware setups.
Original Message
> From: Marie Thelen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=opzn1uS_foqgaOyRUNT-IyZu1xpbp_ogSy5wYF39vTReK81sk2FIirXR9blgt-dzUodByk-pGKCv]hazemarie@y...[/url
> Sent: Wednesday, March 06, 2002 3:07 PM
> To: basicstamps@yahoogroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] serin freezes
> Go here:
> I hope that helps.
> > www.rentron.com to
> > just freeze on the
> > Rafe
> > ignored.
> Do You Yahoo!?
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
