serin freezes — Parallax Forums
serin freezes
edited 2002-03-06 21:26 in General Discussion
I am using a couple of TWS-434 and RWS-434's from www.rentron.com to
implement radio communication between two BSII's. I am having trouble with
the serin command. I am using the time out feature of the command, and it
works fine for a dozen or so passes and then it hangs. The actual code is:
SERIN RFIn, Baud3, 100, TryAgain, [noparse][[/noparse]wait{"Base"),TPacketCount, TPacketData]
When there is no incoming data, the program control will loop through the
TryAgain jump roughly 6 to 25 times and then it will just freeze on the
above line of code. Any thoughts?
Rafe
    edited 2002-03-06 21:06
    Go here:
    http://www.rentron.com/Stamp_RF.htm
    I hope that helps.
    > www.rentron.com to
    > just freeze on the
    > Rafe
    > from the same email address that you subscribed.
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do You Yahoo!?
    Try FREE Yahoo! Mail - the world's greatest free email!
    http://mail.yahoo.com/
    I started with that code. Thanks anyway. What I have now has to do with
    the time out feature or SERIN. I'll play with the hardware and see if it
    happens with different hardware setups.
    > From: Marie Thelen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=opzn1uS_foqgaOyRUNT-IyZu1xpbp_ogSy5wYF39vTReK81sk2FIirXR9blgt-dzUodByk-pGKCv]hazemarie@y...[/url
    > Sent: Wednesday, March 06, 2002 3:07 PM
    > Subject: Re: [noparse][[/noparse]basicstamps] serin freezes
    > Go here:
    > I hope that helps.
    > > www.rentron.com to
    > > just freeze on the
    > > Rafe
    > > ignored.
    > Do You Yahoo!?
    > from the same email address that you subscribed. Text in the
