High Speed Transistor
Hello,
Does anyone know of a good high speed transitor to control a 24V
motor at a couple amps? The use for this is for PWM speed controller.
Thanks in advance,
Travis Manderson
Thanks in advance,
Travis Manderson
make a real big differance.
you can control the motor one direction only with 1 device, but forward
reverse requires 4 or more devices in an "H" bridge configuration.
normdoty@h...
>From: "travis_gm" <travis_gm@y...>
>Reply-To: basicstamps@yahoogroups.com
>Subject: [noparse][[/noparse]basicstamps] High Speed Transistor
>Date: Fri, 01 Mar 2002 21:44:48 -0000
>Hello,
>Thanks in advance,
> Travis Manderson
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
_________________________________________________________________
Chat with friends online, try MSN Messenger: http://messenger.msn.com
