Audio to PWM?
HELP!
I have had no luck finding the info I need.
I need to convert audio output from my sound source to control a servo.
In other words....
The louder the sound the longer the servo movement.
any suggestions...
please remember I am not an EE.
Thanks.
Rus
In other words....
any suggestions...
Thanks.
Rus
Check out the Visual Servo Automation product from Brookshire Software
www.brookshiresoftware.com
Hope this helps,
Rich
Original Message
From: Rus Hardy [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=F4FTutS_kEOtQff0nF5ahOMOCgEQmCoYX7XRalLfUAqRQPz8aNLVN90Igj14KelFve2hPtJ4mcFj0pmeQ67E5H_H]rushardy@m...[/url
Sent: Friday, March 01, 2002 9:02 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Audio to PWM?
HELP!
In other words....
any suggestions...
Thanks.
Rus
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
with micros. It involved a 'robot' head on a motor gearing which
turned in the direction of the loudest noise. I used a PIC, and even
had it connected to a PC for programming in routines through a VB
interface (it did more than just turn).
But to capture and hold the short noise, I used an op-amp in a sample
and hold configuration. The 'mic' charges up a cap, and the op-amp
slowly bleeds it off. The difference in level between the left-ear
and right-ear would be cause it to turn in one direction or the other.
I believe there is a sample and hold circuit in the Stamp manual (old
one) for PWM output that may be modified. Also, we discuss sample
and hold in the Industrial Text.
Martin Hebel
Need a GUI for your Stamp?
http://www.selmaware.com/stampplot
Original Message
> From: Rus Hardy [noparse][[/noparse]mailto:rushardy@m...]
> To: basicstamps@y...
> HELP!
servo.
> In other words....
> any suggestions...
> Thanks.
> Rus
> basicstamps-unsubscribe@y...
Subject
