Audio to PWM? — Parallax Forums
Audio to PWM?
edited 2002-03-06 05:40 in General Discussion
HELP!
I have had no luck finding the info I need.
I need to convert audio output from my sound source to control a servo.
In other words....
The louder the sound the longer the servo movement.
any suggestions...
please remember I am not an EE.
Thanks.
Rus
    edited 2002-03-01 15:14
    Hi Rus,
    Check out the Visual Servo Automation product from Brookshire Software
    www.brookshiresoftware.com
    Hope this helps,
    Rich
    From: Rus Hardy [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=F4FTutS_kEOtQff0nF5ahOMOCgEQmCoYX7XRalLfUAqRQPz8aNLVN90Igj14KelFve2hPtJ4mcFj0pmeQ67E5H_H]rushardy@m...[/url
    Sent: Friday, March 01, 2002 9:02 AM
    Subject: [noparse][[/noparse]basicstamps] Audio to PWM?
    HELP!
    In other words....
    any suggestions...
    Thanks.
    Rus
    Your use of Yahoo! Groups is subject to
    Actually, I've done something similar before in my first project ever
    with micros. It involved a 'robot' head on a motor gearing which
    turned in the direction of the loudest noise. I used a PIC, and even
    had it connected to a PC for programming in routines through a VB
    interface (it did more than just turn).
    But to capture and hold the short noise, I used an op-amp in a sample
    and hold configuration. The 'mic' charges up a cap, and the op-amp
    slowly bleeds it off. The difference in level between the left-ear
    and right-ear would be cause it to turn in one direction or the other.
    I believe there is a sample and hold circuit in the Stamp manual (old
    one) for PWM output that may be modified. Also, we discuss sample
    and hold in the Industrial Text.
    Martin Hebel
    Need a GUI for your Stamp?
    http://www.selmaware.com/stampplot
    > From: Rus Hardy [noparse][[/noparse]mailto:rushardy@m...]
    > To: basicstamps@y...
    > HELP!
    servo.
    > In other words....
    > any suggestions...
    > Thanks.
    > Rus
    > basicstamps-unsubscribe@y...
    Subject
